remount tires to compensate for outside shoulder wear?
Old Oct 5, 2005 | 06:17 AM
snid's Avatar
snid
Has anyone had their (track used) tires unmounted from the rims then remounted for the other side of the car? My tires are directional, so you cannot just take the wheel and tire from the left side and put it on the right side, it will be rotating the wrong way. But, the tires are symmetrical, so there is no "inside" or "outside" of the tire. You could unmount the tires, then remount with the old outside now on the inside.
I've got a lot of wear on the outside shoulders of my tires, but the inside shoulders are looking pretty good. Would it be worth the cost of getting them remounted? Would I be asking for strange handling as the tire wear already on the tires would be all wrong?
I think I can get 2 more track days out of my tires, then it's snow tire time anyway... so it might be a moot question.
Old Oct 5, 2005 | 08:55 AM
JeffS's Avatar
JeffS
Sure, it's done all the time.
You have to put a dollar value on the amount of life you'd be losing by not flipping them, then compare that to the cost of having them flipped.
Old Oct 5, 2005 | 10:07 AM
caminifan's Avatar
caminifan
Minor point, but - be sure to include the cost of road force balancing as well into the calculation.
Old Oct 5, 2005 | 10:11 AM
JeffS's Avatar
JeffS
Does mounting ever not include balancing?
Old Oct 5, 2005 | 10:31 AM
caminifan's Avatar
caminifan
Two points: In my neck of the woods, balancing is an additional cost item; second, I specifically mentioned road force balancing, which is a more exacting balancing procedure (and therefore is priced higher than regular spin balancing). If you are going to be attempting to extend the life of used tires, I personally would want them to be balanced spot on. Road force balancing gets as close to perfect balance as is presently possible. If for some reason, there is an internal fault with the tire that prevents it being road force balanced, I would rather replace the tire than try to get one or two more track sessions in on it - you might regret the decision to extend the tire's use if you were to get in a crash due to failure of the tire....
Spank
11
Apr 9, 2020 02:23 PM
W0TM8
Dec 19, 2019 07:50 AM
Waszak
Oct 21, 2017 05:55 PM
molala
Oct 2, 2015 01:53 PM
Ntety
Sep 2, 2015 08:39 PM
