*not for use with run-flat tires
Old Jan 29, 2003 | 05:02 PM
Verruckt's Avatar
Verruckt
How valid is this disclaimer? I have seen in with several aftermarket wheel companies, notably everything sold through MOSS MINI. ARE there some aftermarket wheels that you can't use run-flats with? How can you tell which ones you CAN use them with?
Old Feb 5, 2003 | 08:24 PM
Verruckt's Avatar
Verruckt
Hey, come on SOMEONE must know why some aftermarket wheels say not for use with run-flats. I want to run my run-flats at least until they need replacing. But I would also love to get lighter wheels. What to do? Which can I use? Dan@tirerack, can you help?
_________________
Lean, Mean, British Green, MINI Cooper 'S' Machine!
(G.I.R.)
Old Feb 6, 2003 | 08:57 AM
Alex@tirerack's Avatar
Alex@tirerack
We're currently researching with Pirelli on this topic. Certain wheels have a saftey hump that may be too large for use with run flats.
A safety hump is a circumferential rib just inboard of the bead seat area of a wheel, about 1 inch. Its designed to keep the beat of the tire seated on the tire in the event that there was a catastrophic loss of pressure.
Run flat tires tent to have incredibly rigid sidewalls, and the bead seat area tends to be even stronger than the sidewall. When a tire is mounted the bead are placed into the drop center (middle of the wheel) Pressure in the new wheel tire assembly is raised until the beads jump over the safety hump and and the bead is "seated"
The extra rigidity of run flats may not be able to clear large safety humps. We're researching the conditions that apply to the mini under these circumstances. I will post when we have answers.
Dan
_________________
MCO tire and wheel forum Moderator
Old Feb 6, 2003 | 09:00 AM
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
Very interesting (and helpful) info as usual, Dan! Thanks.
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
