Alta vs MiniMania Pulley
Old Sep 11, 2005 | 05:16 AM
ignote's Avatar
ignote
Which 15% pulley is better and why is it better?
Or is there really a difference?
Old Sep 11, 2005 | 07:04 AM
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
I had the MM 15% then switched to the Alta 19%. Zero troubles with either. Probably the only difference would be installation. I had both done professionally so I can't comment on that.
Old Sep 11, 2005 | 07:12 AM
karvinbass's Avatar
karvinbass
Why not Helix?
Old Sep 11, 2005 | 08:31 AM
Veni_Vidi_Vici
Does Helix make their own or is it a rebadged version? For that matter, how many different pullies are there, really?
Old Sep 11, 2005 | 08:47 AM
ignote's Avatar
ignote
Originally Posted by karvinbass
Why not Helix?
I can get the MiniMania pulley installed close to where I live and Randy Webb will be in the DC area next month. So I kind of wanted to just talk about the two pulleys.
What does Helix offer over the other two?
Old Sep 11, 2005 | 02:04 PM
vegasdan's Avatar
vegasdan
Which ever pulley you end up with, get a stainless steel pulley, not an aluminum.
Old Sep 11, 2005 | 03:56 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Helix offers there own brand that is a unique pulley.
For the record, I can install just about any brand out there, and I choose to use the M7, Alta and now Helix pulley.
Why? There are a few reasons.
First, the supercharger shaft is steel. The pulleys above are all steel as well (albeit stainless) which have close to the same thermal expansion properties as the shaft. There are no keys or bolts holding the pulley onto the shaft, it is a taper bore interference fit. That makes thermal expansion an issue to consider. Aluminum has vastly different expansion properties.
Second, all of the above have a positive stop surface on the inside face of the pulley for the shaft. That makes alignment a cinch.
Third, they all have very easy methods of removal. That doesn't sound like an issue now, but what if down the road you want a change (like a TurboKompressor kit for instance)? Now you wish it was a lot easier to swap pulleys (one of the key reasons I don't use the Mania pulley).
Lastly, the aluminum types have a much higher tendency toward corrosion, whereas all of the above units are stainless steel.
There have also been some vendors trying to sell pulleys made of aluminum by stating how much lighter their brand X is. The truth of the matter is, the radius of the pulley is less than 1.25" making the rotational mass just about totally insignificant. We could make the unit out of iron from railroad rails with no appreciable loss in performance over a magnesium unit (we tested the lack of difference in stainless compared to aluminum).
I hope that helps a bit. There are certainly a number of units on the market, and you have to choose wisely. Most are high quality pieces.
If we do the install of any of the above brands, we warranty our work and parts. We have now installed over 650 pulleys across the country!
Hope that helps,
Randy
Old Sep 11, 2005 | 05:37 PM
fishbulb's Avatar
fishbulb
randy,
thank you for putting that all out on the table... Makes it that much harder to choose between you & Helix (my local guy)!!!
-jac
Old Sep 11, 2005 | 06:46 PM
ignote's Avatar
ignote
Hope that helps,
Randy
Randy,
When you do the installs, do you use a different belt?
Old Sep 11, 2005 | 07:45 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
No, we have had zero problems with the 15% pulley and the stock belt. That can't be said for other belt types, where we have seen failures in testing. It is one of the reasons I like the 15% pulley (among others). If you use the 16% M7, I do use another belt that is slightly shorter. If you use a belt that is too small, it tends to shred.
Hope that helps!
Randy
Old Sep 17, 2005 | 12:45 PM
Tweeker1's Avatar
Tweeker1
I getting to really like the way Randy talks, "Railroad Ties", I am still laughing about it! Randy knows his stuff, that is for sure, so whenever he gets into the forum, I listening!
Since 9/02 I have had a 15% non aluminum pulley and have never had any problems. I don't even remember the make of the pulley, though I remember the removal!
rtk90
Aug 29, 2019 09:08 AM
The_Kid
Nov 3, 2016 06:30 PM
Suspension Products
Sep 2, 2015 10:32 AM
Sep 2, 2015 09:05 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
