Interior/Exterior Hamman bits - Pictures and install advice
Old Sep 7, 2005 | 06:45 AM
TWISTER's Avatar
TWISTER
I've got a few pieces coming and I'd like some pictures and advice before doing the installs. TIA
Old Sep 23, 2005 | 10:27 AM
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Final pics
This morning I took some pictures of the Hamann rear diffuser and front splitter for another NAM member with install questions. Here's a couple shots to show you how the mounting brackets and final look.
My only word of advice is: on the front splitter use expanding foam to fill in the gap on the underside. Otherwise, if/when you accidentally tap the ground coming out of a driveway, etc. the splitter could compress the gap and crack the fiberglass.
Hamann, if you're out there...you might want to beef this up for your future customers.
Attached Thumbnails Hamman bits - Pictures and install advice-front-splitter-small.jpg   Hamman bits - Pictures and install advice-rear-diffuser-small.jpg   Hamman bits - Pictures and install advice-side-profile-small.jpg
Old Sep 23, 2005 | 10:28 AM
Fracky's Avatar
Fracky
Here's the other pics....
Attached Thumbnails Hamman bits - Pictures and install advice-top-diffuser-bracket-small.jpg   Hamman bits - Pictures and install advice-top-view-of-rear-diffuser-mount-small.jpg
Old Sep 23, 2005 | 10:38 AM
J0kER's Avatar
J0kER
no doubt bout it!!! when i got my splitter i was totally let down w/its construction, and the mountin' points!! who does that? they R so flimsy that if u hit anything it will fall off it needs reinforcement which is what im workin' on now......but i still like HAMANN bitz there right up my alley...
good idea bout the foam stuff
Old Sep 23, 2005 | 10:39 AM
TWISTER's Avatar
TWISTER
Joker let me know how it goes.Thanks!
Old Sep 23, 2005 | 11:09 AM
Fracky's Avatar
Fracky
Don't even get me started on the flimsy construction and mounting hardware for the splitter. When I first installed the splitter, it only lasted 36hours on my car before flying off and smashing all over the freeway. To add insult to injury, CA Highway patrol pulls up behind me (while my car is parked on the side of the freeway and I'm putting the broken pieces in the back of the car) and proceeded to write me a ticket for window tint and non-factory body modifications.
Hamann has some sweet gear, but their customer service sucks. After two months of asking for another splitter or to at least help repair mine, I gave up and took it to a body shop and had it re-painted.
When I re-attached the splitter, I used five grade-5 (super-hard) fine thread bolts and aluminum mounting plates. Basically, you need to take the front-end of my car off to get it off. No more gliding body parts on the freeway.
Old Sep 23, 2005 | 11:35 AM
J0kER's Avatar
J0kER
dood, thats exactly why i panic to mount this unit on b4 serious overhauling...........how bout some pix of what u did to get urs on?
i need to be able to take minie off in the winter months........
Old Sep 23, 2005 | 12:37 PM
Fracky's Avatar
Fracky
No problemo. By the end of today I'll have some pictures for y'all to see how to rig your very own Hamann splitter! <said in my best Bob Barker voice>
Old Sep 23, 2005 | 12:59 PM
VoiD's Avatar
VoiD
Foam is a very good idea!
Joker.. when are you going to put the spoiler on? I wanna see it!
Old Sep 23, 2005 | 07:28 PM
Fracky's Avatar
Fracky
Alrighty then, here's some pics of the Hamann splitter. Our Cooper has H-Sport springs so the car is already lowered. With the splitter and springs, I have about 3" of ground clearance. I've included two pictures for anyone thinking of putting one of these on their lowered Mini. Also, here's a shot of the foam in the underside gap.
I sprayed the foam in the gap, allowed to dry, cut away the excess with a knife and lightly sanded the dried product. Note: you have to get under the car to see the foam.
Oh, in case anyone is wondering why the Euro license plate is blurry, we have a photo deflector lense. <evil cackle> Here's a fun site to play around on: http://www.jammersstore.com/p_photo_blocker_covers.htm Cheers.
Attached Thumbnails Hamman bits - Pictures and install advice-ground-clearance.jpg   Hamman bits - Pictures and install advice-bottom-trailing-edge2.jpg   Hamman bits - Pictures and install advice-top-view-clearance.jpg
Old Sep 24, 2005 | 09:28 AM
jm6001's Avatar
jm6001
Hello,
I was wondering if the Hamann front spliter will fit on the Aero kit front bumper as well?
Jm
Old Sep 24, 2005 | 01:02 PM
J0kER's Avatar
J0kER
right-on
3" of clearance is good! on H-sports? is it more or less, since u stated "about" did u even use the mountin' hardware provided cuz it also looks real Mickey Mouse..............
Old Sep 24, 2005 | 01:07 PM
Fracky's Avatar
Fracky
The first time I put the splitter on the car, I used all of the Hamann mounting hardware provided (time on Mini= 36 hours). Then, I used the mounting plates provided and upgraded the bolts (time on Mini= 16months).
Old Sep 24, 2005 | 01:51 PM
Gr8Force's Avatar
Gr8Force
You've just convinced me to go with the Orciari kit.
Old Sep 24, 2005 | 05:20 PM
J0kER's Avatar
J0kER
they dont make a splitter!
Old Sep 24, 2005 | 05:31 PM
Gr8Force's Avatar
Gr8Force
And that means...
Old Sep 24, 2005 | 05:37 PM
J0kER's Avatar
J0kER
well since the topic is about splitters i assumed thats what ur referin' to
And that means...
Old Sep 24, 2005 | 05:43 PM
Gr8Force's Avatar
Gr8Force
Actually the thread is about Hamann bits - Pictures and install advice. I assumed the difficulty in making this kit work would compare it to the ease of installation of other body kits in general.
Old Sep 24, 2005 | 05:49 PM
J0kER's Avatar
J0kER
yea ur right but the topic has been more bout the splitters than the body kit.....its not that hard to install it just needs a little tweaking like any other kit would...... i've heard that the kit u refer is not that easy to install but then again its a matter of opinion when it comes to how well u work w/ and around tools!
Old Sep 24, 2005 | 05:53 PM
Gr8Force's Avatar
Gr8Force
tru dat
Old Sep 24, 2005 | 06:01 PM
J0kER's Avatar
J0kER
we need to introduce some alternative language up in this JOINT!!!!
oh man u better b carefull using that kinda slang around here d00d, u will get hung...chew out...bitched at and put down for beign stoopid!!!! (check some of my posts u'll see)
but hey i still use it cuz I CAN & dont give a ******........ so power 2 U G'
peace out
=Gr8Force]tru dat
Old Sep 24, 2005 | 06:07 PM
Gr8Force's Avatar
Gr8Force
I hear you brudda
On the up and up I'm still working on putting together the plan for the details on Icarus. Considering he's a cab I'm ruling out him being a true track car. I'll save that for the second MINI. This one will be more show than go.
Old Jul 10, 2006 | 01:39 PM
acitydweller's Avatar
acitydweller
this is really disappointing to hear on the hamann parts. I am only interested in the rear diffusor but now having second thoughts.
Old Jul 11, 2006 | 06:00 PM
J0kER's Avatar
J0kER
tha rear diffuser is not an issue, its tha front that is a b!tch.......
but now that i've installed a few body parts on my homies cars its really not a big deal u jus gotta plan it out b4 u jump in 'n do ti
Old Jul 12, 2006 | 09:18 AM
acitydweller
Anyone know where i can get the rears from?
