2002 Mini Cooper S Brake Pad Replacement. Need help!!
Old Aug 14, 2005 | 01:13 PM
vgrillone's Avatar
vgrillone
I need to replace my brake pads and I understand that the callipers screw in. Has anyone done this without using the speacial tool. If so, how? I've tried using a wrench to grip the round calliper plate and screw it on. Thanks for your help.
Old Aug 14, 2005 | 06:37 PM
sdiver's Avatar
sdiver
Harbor Freight Tools has a caliper tool set that works quite well for the rear brakes
CALIPER TOOL SET FOR DISC BRAKES
Definitely makes life easier...
Old Aug 14, 2005 | 06:54 PM
onasled's Avatar
onasled
Only the rears need to have the pistons turned clockwise while being pushed back in. This is due to an integrated E-Brake.
I successfully do these with a larger 'C' clamp. The C clamp will spin this piston while pushing it in.
I did a friends like this at the track when in fact his piston was too far out to fit that specialty tool that most use. It did not work at first, but once I got the piston to spin with channel locks, the C clamp then worked perfectly on it's own. The other side only took the C clamp.
One time the C clamp proves to be as good if not better then the tool.
Old Aug 14, 2005 | 08:16 PM
vgrillone's Avatar
vgrillone
Thanks tons for the feedback. Now I know what the heck to do.
Regards!
Mini'mon
Aug 16, 2015 04:15 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
