Solo Street tires/rain tires for Solo II
Old Jul 18, 2005 | 04:58 PM
DaCrema's Avatar
DaCrema
I have a set of Hoosers now for the dry. Looking for a every day spring/summer/fall tire that could be a rain tire if needed. Driving on 16 x 6.5 AK Monza's. I have Falkin Azenis on the car now. They are getting a little thin for the rain in Washington DC (though they still have some autocross life in them). I thought they did ok in the rain (street that is) when there was tread, but the ride was a bit hard. The biggist gripe is that the weight but that is not so bad because the grip is good.
Any ideas?
John D
7HS
A very slow H stocker - but it is sooo much fun.
Old Jul 18, 2005 | 05:22 PM
nygaard's Avatar
nygaard
I would consider the 225/45R16 Hankook ventus RS2 or whatever the new one is. It is the closest to stock diameter that I have found. I was considering this route, but decided that I will probably end up going with Hoosier Wets instead.
Jake
Old Jul 28, 2005 | 07:26 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Any ideas?
John D
7HS
You have your Hoosiers on what rims?
And you want street tires on the Monzas or on X-lytes?
For street tires that can be used in the rain there are several options from those that are more expensive like Goodyear Eagle F1 GS-D3 and Bridgestone Potenza S-03 to those that are more economic like Yokohama AVS ES100 or Avon Tech M500.
If you want to use the street tires for autocross/wet performance driving then consider
http://edgeracing.com/tire/1517/
Hankook Ventus Rs2 Z212
215/45R16
20.5Lbs.
200 Treadwear
MAX PERFORMANCE
W Rated
$85 each
23.6" outer tire diameter.
Old Jul 29, 2005 | 02:42 AM
DaCrema's Avatar
DaCrema
I have three sets of wheels for the car. All are 16x6.5 inches. The stock rims will be for winter. I use the two lite sets for autocross and summer street tires. Thanks for the help.
John
Old Jul 29, 2005 | 08:17 PM
minihune's Avatar
minihune
John
I have dedicated wheels and tires for:
autocross
autocross fun runs (older autocross tires that are worn)
track
Street use- which doubles for wet autocross
Street/ car shows
The Hankook Ventus Rs2 should work for you, but are really an alternative to true race rubber on a budget and under dry conditions. Personally I favor getting good street rubber that performs well in the wet like Bridgestone Potenza S-03 or Goodyear Eagle F1 GS-D3s, only problem is the expense.
Old Aug 31, 2005 | 06:32 PM
autoxgod's Avatar
autoxgod
Rain tires for sale
I have a set of very nice goodyear eagle F1GS D3's in 205/50-16 that are very good street and rains. Also a set of slightly used Kumho 205/45-16 V700's that are fine as intermediate rains or below 50F cold weather race tires or summer street use tires. $400 for either set shipped. The Eagles are really great in major water-heavy downpour or puddles. The Kumho's are great when it's damp but not really dry enough for full race tires.
Jim
Waszak
Oct 21, 2017 05:55 PM
molala
Oct 2, 2015 01:53 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
Sep 4, 2015 09:23 AM
Ntety
Sep 2, 2015 08:39 PM
