Getrag 6 in a Cooper?
Old May 11, 2005 | 11:45 AM
ahamos's Avatar
ahamos
Coordinator :: River City Minis
Does anyone know if a 6spd Getrag will fit into a Cooper without *too* much fabrication? Does the Getrag mount to the same places and mate with the engine in the same location? Since MINI tried to use the R65 Midlands unit first, this seems like a reasonable question.
Thanks!!
Old May 11, 2005 | 12:41 PM
astra's Avatar
astra
Oh,... it's a bunch of work..
there is one running around so cal right now..
Old May 11, 2005 | 01:04 PM
lotsie's Avatar
lotsie
The Gertag 5 speed would probably be way easier.
I had my Midlands tranny replaced this winter.The axle seal went because of extreme cold.MINI does not see this as a tranny problem,even though the fluid drains from the tranny,and wrecks the tranny, but an axle seal problem.So you get a Midlands,not a Gertag[till they run out of Midlands I guess]Anyway I asked how much to get the Gertag instead of the Midlands.The dealer said full price $3000 CND,but they would do the install under warrenty.Needless to say I have a new Midlands
Old May 11, 2005 | 01:19 PM
vegasdan's Avatar
vegasdan
I think ABBA said it best, "Money, money. Always sunny, in a rich man's world. All the things I could do if I had a little money."
Old May 11, 2005 | 01:21 PM
ahamos's Avatar
ahamos
Astra, is it more work than replacing the transmission would normally be?
Do you know who has the lone known Getrag 6 Cooper?
I've found a deal for one, and have been considering going the turbo route for some time. The tranny is one of the key ingredients to getting reliable turbo power.
Unfortunately, my Bentley manual is on loan at the moment.
Old May 11, 2005 | 01:27 PM
tradiuz's Avatar
tradiuz
MTH Specialist
Getrag 5 in a cooper that has a midland would be a feat to see as well, since it mounts differently (Look under the bonnet of an '04 vs an '05, you'll see motormounts moved, new airbox, ect)
Old May 11, 2005 | 06:28 PM
El Diablito Rojo-N20Mini's Avatar
it's your worst nightmare! Axels, different flywheel / pressure plate..... nothing matches up.... think twice
Old May 14, 2005 | 08:03 AM
goin440's Avatar
goin440
Since your wanting turbo power, it might be easier and cheaper to find a wrecked MCS and swap the motors, less top-mount cooler of course.
Old May 14, 2005 | 08:21 AM
ahamos's Avatar
ahamos
Well, the point is now moot. It was an e-bay auction that I was excited about because the part was (relatively) local.
I appreciate the replies. I had been wondering about this since just after buying my Cooper.
I've heard conflicting reports on the matter, but the Brits seem to have thought the Getrag was overkill, even for the S. When original production began, they believed the R65 Midlands unit would be just fine.
With that in mind, I've been wondering about just replacing the drive axles with the MiniMania "beefed-up" axles (I've finally gotten contact info for the actual manufacturer, and I'll be calling them shortly for specific details) and some forged pistons and rods. Again, my manual is AWOL, but I seem to recall the bore and stroke are the same between the Cooper and the S.
Couple the rods, pistons, and Schrick cam with one of those fancy "remote turbos" (to move a tiny bit of weight to the back of the car), and I just might have myself a little monster.
All of that, of course, with CF bonnet and quarter-panels.
Every boy can dream, right?
Old May 14, 2005 | 08:26 AM
goin440's Avatar
goin440
CF Bonnet for the MC w/o scoop? Is one even available?
Old May 14, 2005 | 04:22 PM
ahamos's Avatar
ahamos
I've been searching high and low. There are shops to which I could take my car, and they would make a cast of my bonnet. There's even one within 60 miles, but it would be cost prohibitive if others weren't also interested. The S bonnet will fit, but I wouldn't be thrilled about it.
Didn't I say that every boy can dream?
Old May 15, 2005 | 04:21 PM
mdsbrain's Avatar
mdsbrain
I found this one on Ebay. Super cheap
$995 Buy in now
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old May 15, 2005 | 04:47 PM
JeffS's Avatar
JeffS
$995 Buy in now
Be careful with this seller. Something's not right
1) he's re-using pictures from another auction that just ended
2) he couldn't tell me what year it was out of (though he did say it wasn't an '05)
Mainly, I just have a big problem with people using other people's pictures. It's unethical IMO unless a disclaimer is placed in the ad.
Old May 15, 2005 | 05:35 PM
mdsbrain's Avatar
mdsbrain
Two very valid points. I didn't notice that.
Old Nov 3, 2009 | 12:01 PM
myla2003's Avatar
myla2003
I'm actually putting a Getrag 6 speed in my bone stock 2003 MC right now. It's expensive, and a lot of work, but not to crazy if you can find all of the right parts. The transmission matches up perfect, but you need new axles, and a load of other things to make it work. I'm definatly assuming I'm gonna want to go turbo after I put this in though. I'll update when I'm done. -only trying to find one more part.....
Old Nov 3, 2009 | 02:00 PM
Densmini's Avatar
Densmini
Check out the 5-to-6 speed how-to from Texas Motorwerks...there's a link here somewhere. I went from a CVT to a 6-speed, so if yours is already a manual, you're way ahead!
Old Nov 3, 2009 | 02:08 PM
myla2003's Avatar
myla2003
I've already done the swap, that how-to really helped. I'm just having an issue with the RH axle. The one I bought didn't come with the carrier/bearing assembly, and I am now having trouble figuring out why my old one doesn't fit, or where to get one. I can't even find any axles online anymore, and I'm trying to avoid going to the dealer.
Emnotek
Aug 13, 2015 05:47 PM
Aug 12, 2015 01:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
