2012 Mini Cooper R56 JCW
2012 Mini R56: "Mk II" Mini Hatch/Hardtop range
  • 2012 Mini R56: "Mk II" Mini Hatch/Hardtop range - 2012 Mini Cooper R56 JCW - Used - VIN WMWSV9C59CT499130 - 107,363 Miles - 4 cyl - 2WD - Manual - Hatchback - Gray - Savannah, GA 31324, United States
Alliance Member
Veteran: Army
    $13,500
    • OBO
  • Location Savannah, GA, 31324, USA
  • VIN WMWSV9C59CT499130
  • Mileage 107,363
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Gray
Savannah, GA
$13,500
Not interested in trades or parting out. Any requests will be ignored.
 I actually purchased this vehicle from another NAM member back in June 2021.  My son had actually purchased a MINI for his first vehicle and I wanted to learn more about the maintenance to be able to teach him so I purchased this one for myself.  I actually flew from Savannah, GA to Baltimore, MD and purchased the vehicle from another MINI enthusiast who took great care of it.
 Fast forward almost 4 1/2 years and I never thought this day may come but I have another MINI moving into the stable soon and as you may know, old toys tend to get neglected.  However, since my ownership from Day 1 this has car has been nothing but fun, enjoyable and well taken care of.  Always garage kept, routine oil changes @5k miles with Liqui Moly 5w-40 & OEM Purflux oil filters to include scheduled coolant and brake flushes as required.
 For the most part this car is near perfect and with the tune it's a blast to drive.  The DervTech Stage 2 Tune is toggled by the Sport Mode button for Full Tune Activation pushing 22 PSI of boost.   In normal mode, your boost levels max at 11 PSI.  This was an optional programming that I wanted so I the car's not always in Full Tune Mode. (Georgia State Patrol doesn't play).
 I say near perfect because the exterior does have small dings and scratches for being 13 years old but nothing major. The worst is a scrape along the passenger side skirt from the previous owner hitting a road gator that he couldn't avoid. It wasn't enough of concern for me to want repair since it's not noticeable unless you look for it. Interior is almost flawless with no rips, stains, tears, smells and the bolster in both seats are solid.
 Other than that, the only CON to this vehicle is that the front brake rotors may be slightly warped.  I recently them installed this past September 2025 and they are either warped or the material transfer from the new brake pads did not wear/burn in evenly.  It's so minimal that I haven't had the desire to address it to determine the cause and correct it.
 Below I have done my best to list every modification I have made to include services performed that I still have receipts to provide. I may have missed something but if you have any questions, please do not hesitate to reach out. I do have some of the original items that were previously removed such as the rear seats, wipers, lug bolts, heat shield and there might be some other stuff in the garage storage that I can't recall at this moment.
 I understand my asking price is slightly above KBB Private Party Value but I'm taking into consideration the upgrades, modifications, and the meticulous attention to services already performed. I don't need to sell the car but I'm sure there's another enthusiast who would appreciate it.
 Any questions, please feel free to reach out and DM me.
 ***Thule Rack Basket Not Included ***
Exterior
GP Brake Ducts
Aero Wiper Conversion
Windshield Lower Cowl Replaced w/OEM (old one was faded and cracked)
Blacked Out Headlight Trim
SMPS2012 UK Blacked Out Side Scuttle w/ Smoked Lens
KAC Matte Black Door Handle Covers
GP Rear Diffuser Kit
SMPS UK OEM Spec Black Taillights
KAC Matte Black Fuel Door Cover
KAC Matte Black Door Handles
KAC Matte Black Beltline Tape
Side Skirt Piano Black Fin Inserts
Black Front Grille
Powdercoated OEM Thule Roof Bars Semi Gloss Black
20% Tint All Around
Wheels/Tires/Suspension/Brakes
Neuspeed RSe12 18x7.5
Michelin Pilot Sport 5 215/40/18 (purchased Jan 18, 2025 Discount w/ Warranty Certificates)
Stud Conversion Kit 14x1.25 to 14x1.5
5mm spacers (extra 12mm spacers avail.)
Open End Tuner Lugs
Bilstein B8 Struts
HR Drop Springs
Poly Rear Strut Bushings
Alta 19mm Rear Lower Sway Bar w/ WMW greaseable poly sway bar bushings
Alta Adjustable Endlinks (4 corners )
M7 Rear Support Brace
AEM Front Upper Strut Bar
NeuSpeed Short Shift Kit
SP Performance Slotted Rotors & EBC Red Stuff Pads (Sep 2025)
Engine/Exhaust Modifications
Dervtech Stage 2 Tuned (NGK 1422 One Step Colder Plugs & Replaced Coil Packs when tuned)
AEM Cold Air Intake
Scorpion 200 Cell Sport Cat DP
Akrapovic Full Exhaust w/ Carbon Fiber Tips
Alta Upgraded Intercooler
Nm Engineering Silicone Charge Pipes
NM Engineering Resonator Delete
Forge Turbo Blanket
AEM Heat Shield
CravenSpeed Oil Dipstick
M7 Tuning Oil Catch Can
Turbo Smart Dual Port BOV (still have stock)
Interior
OEM All Weather Mats
Pro Clip USA Phone Mount
Schrader Rear Seat Delete (carpeted) rear seats still available
HK Speakers
Ultra Scan Gauge Mount
Notable Maintenance/Services Performed
 -Valve Cover Gasket Replacement
June 2021 63,000 miles
Tom Bush Mini Jacksonville, FL
 -AGM Battery Replacement May 2022
 -Timing Chain & Assy Serviced
(Detroit Tuned N14 Kit)
Jan 2023 @ 81,667 Miles
EC Automotive Specialist, Daytona FL
 -Dervtech Stage 2 Tune
May 2024 @ 94,782 Miles
 -Thermostat and Water Pump Replaced
June 2024 @ 95,616 miles
-FCM Recall Check
Sep 2025 @ 104,515 miles
 -Carbon Walnut Blast Valve Cleaning
Sep 2025 @ 104,597 miles
-Water Pump Pulley and Passenger Motor Mount Replaced
Sep 2025 @ 105,200 miles
