R50/53 Boost leak from fuel injector
Old Nov 12, 2025 | 03:33 PM
gratefulone's Avatar
gratefulone
Hi All, i have a 15lb pulley on my 03 MCS. Over time I noticed that the car has lost power so I did standard maintenance (new sparkplugs, coilpack, tensioner, engine mounts, bpv, etc) and it still felt pretty much the same. I logged a max boost 12 psi via OBD. I nfally did a smoke test via the TMAP senor (I did block off the air intake and noticed smoke coming from the number 2 injector. Has anoyone seen this before? I ordered new injector o rings.
Old Nov 13, 2025 | 07:28 AM
JABowders's Avatar
JABowders
Veteran: Army
O-Rings will parish over time and can leak, so this is possible.
Motor On!
Old Nov 13, 2025 | 12:06 PM
GLEX's Avatar
GLEX
Did you order genuine MINI/BMW o-rings? I'm not sure if it's true, but I've heard there can be (small) size discrepancies with aftermarket injector o-rings.
Not to hijack the thread, but is the TMAP or MAP sensor where everyone is putting smoke into the system while testing? Or is there a more preferable location?
Old Nov 13, 2025 | 12:34 PM
Here2Go's Avatar
Here2Go
NAM Community Team
I bought my JCW 380cc injector refresh kit from: "mrinjector.us" online several years ago. Perfect fit new O-Rings and screens.
Right or wrong I've always done a smoke test from the PCV, detaching/blocking off the air inlet.
Old Nov 13, 2025 | 02:48 PM
gratefulone
Motor On!
Thanks for confirming!
Old Nov 13, 2025 | 02:49 PM
gratefulone
OEM from FCPEuro so not OE. Thanks!
Old Nov 13, 2025 | 02:50 PM
gratefulone
I'll try this too next time I test. Thanks!
mrtutz
Aug 21, 2022 11:01 PM
zcast
Jan 22, 2015 02:50 PM
2005MCS/KK
Sep 12, 2006 07:22 PM
bhcvc
Apr 25, 2002 08:25 PM
