M14x1.25 Stud Conversion + Wheel Locks
For SaleWheels and Tires/Axles
Price
$160
- Location Savannah, GA, 31406, USA
- Condition Used
$160 Shipped
MMX Stud Conversion Kit
80mm
14x1.25
Will fit spacers 10-20 mm
(20) studs with lug nuts
(4) separate wheel locks + key
*Almost new. Had them on the car for less than 500 miles. Reason for removal is went to a smaller spacer and switched stud setup.*
M14 x 1.25 heat treated high carbon steel stud with chrome plated finish
- Lightweight M14 x 1.25 7000-series aluminium open-ended nuts with gloss anodised nuts
- Internal 6mm allen stud drive for accurate fixations
- Knurled outer collar for much easier finger grip
- 8mm of unthreaded stud shank for brake disc clearance
- Oversize 19mm nuts – greater surface area for contact & ease of use
- Thread length (Hub side): 13mm
Thread length (Nut Side): 60 mM
