R50/53 Rattle- Any ideas?
Old Jul 10, 2025 | 05:14 AM
BMH94's Avatar
BMH94
Rattle- Any ideas?
03 r53
1st video is a cold start. Rattle is always there on a cold start. Goes away in like 2-4 seconds
2nd video is holding the throttle. Rattle sound is always there, but not at every rpm. I usually hear the rattle at about 2,500-3,500 rpm. I want to fix this🙂
Any input is welcome!!
Old Jul 10, 2025 | 06:20 AM
mrbean's Avatar
mrbean
The infamous death rattle? A little difficult to hear through the crappy speakers on my device.
I had it once and it went away after replacing the belt tensioner and upgrading to an ATI super damper.
Old Jul 10, 2025 | 07:15 AM
BMH94's Avatar
BMH94
I'll look into the belt tensioner. My car does have an ATI super damper.
Old Jul 10, 2025 | 12:03 PM
ssoliman's Avatar
ssoliman
does not come through on video.
the belt tensioner seems like a good thing to try
get one of these and go searching: https://www.harborfreight.com/mechan...691.html?gQT=1
Obvi: dont stick that in the wrong place with the engine running
Old Jul 10, 2025 | 05:13 PM
BMH94's Avatar
BMH94
If it is the timing chain tensioner, is that a big job?
Thank you all for the help!
Old Jul 11, 2025 | 01:53 AM
LukasH's Avatar
LukasH
It's not a big job but fiddly as the chassis leg is in the way.
Steps to replace would be:
  1. Remove inner wheel arch liner
  2. Remove engine ground strap
  3. Disconnect the black engine vapor can thingy (don't know the official name)
  4. Tension the tensioner and lock it with a pin
  5. Remove belt
  6. Remove 3(?) 10mm bolts that hold the tensioner inplace
  7. Do the reverse with new part
I think the original tensioner was made by SKF but the thing that rattles would be a damper made by Stabilo. Since I'm in Europe I was able to just replace the damper for like $10.
Old Jul 11, 2025 | 02:55 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Wrong tensioner. He's talking about the timing chain tensioner, not the belt tensioner. EZ job. Just unbolt from the backside of the block, install the new one. Plenty of threads and YouTube on this. "Search" is your friend.
Old Jul 11, 2025 | 03:51 AM
BMH94's Avatar
BMH94
I was thinking: If I have to get to the timing chain, to change the timing chain tensioner, I might put a bigger cam. It currently has a shrick cam.
Old Jul 11, 2025 | 04:03 AM
LukasH's Avatar
LukasH
You are right, my bad.
The timing chain tensioner is on the back of the block, below the oil filter housing. It's literally one big bolt to undo.
The timing chain itself isn't that hard to do either, just a lot more work. It involves removing the engine mount, valve cover, crank pulley and timing chain cover. Timing the engine is very easy as there is just one cam and crank sprocket and the marks are easily readable.
My advice would be, before you do any of this, to pull the oil pan and check for timing chain guide debris. The guides are made of plastic and can break into pieces. Then the chain can be slapping around. Although that sound should be far more noticeable in your videos.
Old Jul 11, 2025 | 06:18 AM
BMH94's Avatar
BMH94
I will pull the oil pan 1st! Good suggestion.
Old Aug 18, 2025 | 05:41 PM
BMH94's Avatar
BMH94
New tensioner is in. Still has the same as I stated in my first post. Perhaps a new bent tensioner and idler will cure it.
Old Aug 18, 2025 | 07:19 PM
Here2Go's Avatar
Here2Go
NAM Community Team
From what sounds to me in the 2nd video - My guess would have been the belt tensioner.
Tedious but simple job.
I am no ace mechanic, but I'd heard that noise before.
I too opted to replace just the damper/shock for $20 and while I was at it; I also replaced/upgraded the small rubber bushings with powerflex.
In my case, I was right on the money - the rattle went away.
Old Aug 28, 2025 | 03:23 PM
BMH94's Avatar
BMH94
New timing chain tensioner and new belt tensioner
The real cause, intercoooler cover is rattling.
Old Aug 28, 2025 | 05:08 PM
Here2Go's Avatar
Here2Go
NAM Community Team
well I must admit - That IS a new one for the books.
to be sure
New parts thrown at it can't hurt (but the wallet)...
Glad you figured it out.
Old Aug 28, 2025 | 05:53 PM
BMH94's Avatar
BMH94
Learning experience as well!!
Jckol
Jan 28, 2022 11:22 AM
Frosty1
Aug 1, 2016 12:42 PM
SoundMessage
Dec 28, 2012 03:19 PM
RotaryGuy
Feb 8, 2011 05:22 AM
Wienie
Milwaukee MINIs
Apr 20, 2010 06:56 AM
