R56 2012 base model custom headers (
Old Mar 24, 2025 | 05:08 PM
masterchodeswag's Avatar
masterchodeswag
Before reading further yes I know the collective of “there is no reason to invest money in the base models performance”. I got racing dynamics aftermarket headers and paired it with a 2.25” exhaust and RPM power stage 1 tune (the only one available for base &#128546. Seeing as how our N12/N16 platform have almost nothing available performance wise I have really gotten into studying air flow to see where I can harvest any potential gains even if it is only 1/2hp. From my readings it looks like long tube headers are the way to go. I’m down to be the nut that spends too much money on a custom set of long tubes but the issue I’ve come up with is the placement of the upstream 02 sensor. It seems to be what would keep this from being possible. Can someone more knowledgeable help shed some light on this? Thanks in advance!
This is my Baby
This is my Baby
Old Mar 25, 2025 | 05:13 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you can extend the wiring down to where ever the collector end up, you'll be better off. You want that primary sensor to read all cylinders for best operation. Then, the secondary ("down stream") sensor can go anywhere, since your tune will have it rendered irrelevant anyway.
Old Mar 25, 2025 | 07:28 AM
All4's Avatar
All4
I have a long tube 4-1 header on an N12. Primary O2 location is just beyond the oil pan and secondary is somewhere past the first pair of hangars.
So i made two simple jumper harnesses (one for primary and one for secondary) that extend to the new sensor locations while avoiding hacking up the original engine wiring harness to get that extra length. All you need is the engine harness side plus O2 sensor side connectors, splice the ones for primary together using an appropriate length of wire, same for secondary and then plug it all together.
edited for clarity
Old Mar 25, 2025 | 09:30 AM
masterchodeswag
Do you have a picture?
edited for clarity
Old Mar 25, 2025 | 03:39 PM
All4's Avatar
All4
masterchodeswag
Jan 28, 2022 09:06 AM
g34343greg
Sep 30, 2014 07:09 AM
boomerwang
129
Sep 18, 2013 09:42 PM
Diversion
Sep 21, 2012 09:18 PM
