Dinan mini jcw intake resonator delete pipe
Engine - Intake/Fuel
  • Engine - Intake/Fuel - Dinan mini jcw intake resonator delete pipe - New - -1 to 2026  All Models - Atlanta, GA 30313, United States
    Expired
    Expired
    Expired
    Expired
    $100
    • Trade
  • Location Atlanta, GA, 30313, USA
  • Condition New
DINAN INTAKE RESONATOR DELETE PIPE - 2020-2024 MINI C'MAN JCW DINAN INTAKE RESONATOR DELETE PIPE - 2
Enjoy the raw, unfettered sounds of the intake/turbo with the Dinan Intake Resonator Delete Pipe! The direct replacement upgrade eliminates the sound deadening element of the factory pipe resulting in the natural voice of the intake/turbo to be noticeably restored. Beyond sound suppression the OEM intake resonator also hinders flow with its disruptive multi-directional flow path. This obstructive factory component is instead replaced by 76mm diameter, durable, and lightweight smooth-bore aluminum piping that improves flow for increased turbo efficiency. The black powder coated piping incorporates TIG welded fittings that guarantee seamless fitment with the factory connections in and a nearly concealed aesthetic within the engine bay. Whether or not you are running completely stock or with a variety of 3rd party modifications the Dinan assembly will fit right in. Short of the tempered, outlined, DINAN logo peeking out from just underneath the cowling you will be hard pressed to even realize it's there - that is, until you hear it. Features: Eliminates factory intake resonator to restore natural unfiltered intake/turbo sounds 76mm diameter smooth-bore aluminum piping for improved airflow Upgraded durability and visual appeal via billet aluminum construction w/ TIG welding Direct replacement of OEM pipe Bolt-On Installation
WILL NEED 3.25” COUPLING TO FIT
MINI C'MAN S/JCW DINAN INTAKE RESONATOR DELETE PIPE - 2018-2019
INCLUDES FREE SHIPPING USA ONLY
Old Dec 6, 2025 | 03:48 PM
Chichihuil's Avatar
Chichihuil
oooh. intetested. but id need to upgrade my full exhaust to 3.25?
I mean, I was gonna go with 3, but.. havent found one yet
