Replacement Shift Boot/Gaiter Trim Ring (3D-Printed) [Ver. 2.0]
Interior/Upholstery
  • Interior/Upholstery - Replacement Shift Boot/Gaiter Trim Ring (3D-Printed) [Ver. 2.0] - New - All Years  All Models - All Years  All Models - Holt, MI 48842, United States
    $40
  • Location Holt, MI, 48842, USA
  • Condition New
Shift Boot Trim (front console); Version 3.0 is re-engineered for better fitment and integrity and comes with a Transient Glow-in-the-Dark MINI Logo.
Inspiration:
My friend wanted a new shift **** in her MINI, and the trim ring broke when the old one was removed. She wanted to retain the elegance in her JCW by not replacing the trim ring with a popular alternative shifter well trim that exposes the shift rod, making her car look like a race car. To retain the JCW appeal, I designed these trim rings so the red stitch/black leatherette boot could be reused.
What it is:
3D-printed shifter trim and boot/gaiter retainer for Gen 2 MINI Coopers. The material is Nylon-12 reinforced with carbon fiber (PA12-CF) and annealed at 80 C for 6 h. This piece is usually only found grouped with complete boot/shifter **** assemblies costing more than $98. This option offers an inexpensive alternative to keep the original boot stying that came with your MINI if the retainer clips break when replacing shifter components
Stock: continuously renews
(NOTE: This is NOT the smaller diameter trim piece for the front cupholder (51162756166))
This piece is typically part of an assembly, such as (25112753783), costing between $98 and $130, and is commonly broken when removing the boot/gaiter to change the shifter **** or linkage.
Based on RealOEM: Compatible Years and Models
MINI R56   (10/2005 — 08/2010)
MINI R56 LCI   (03/2009 — 11/2013)
MINI Clubman R55   (10/2006 — 07/2010)
MINI Clubman R55 LCI   (03/2009 — 06/2014)
MINI Cabrio R57   (10/2007 — 07/2010)
MINI Cabrio R57 LCI   (04/2009 — 06/2015)
MINI Coupé R58   (12/2010 — 05/2015)
MINI Roadster R59   (01/2011 — 04/2015)
3D-Printed from PAC12-CF (Carbon Fiber reinforced Nylon)
Buyer can use as is or prime and paint.
NOTE:
• Pressure should be applied so the boot clips enter the receptacle evenly (video is here).
• While this adapter is made from similarly rigid material as the OEM (CF-ABS: carbon fiber ABS plastic), clips will break if they are not aligned with the receiving slots in the console. Ensure the clips are "clocked" correctly.
• It is challenging to remove the item from the topside after it's inserted into the console, so, plan accordingly or remove the clips from the bottom.
Without MINI Logo
Available on eBay
https://www.ebay.com/itm/167247300410
MINI Logo
Available on eBay
https://www.ebay.com/itm/167254103938
