MINI R56/7/8/9: 1 Shifter Boot Trim + 2 Cupholder Trims (Various)
For SaleInterior/Upholstery
Price
$30
- Location Holt, MI, 48842, USA
- Condition New
Price range: $30 to $100 depending on the chosen variant.
3D-printed shifter trim ring for boot (25112753783, 25117624269/70/71/72) and cupholder trim rings (51162756163) in R56/7/8/9 Gen 2 MINI Coopers. The material is Nylon-12 reinforced with carbon fiber (PA12-CF) and annealed at 80 C for 6 h. For those less comfortable with P2P transactions please find identical item listed here (Click here)
The shifter trim ring is usually only found grouped with complete boot/shifter **** assemblies costing more than $98. This option offers an inexpensive alternative to keep the original boot styling that came with your MINI if the retainer clips break when replacing shifter components
The matching cupholder trim rings are constructed out of the same PA12-CF or ASA polymer material as the shifter trim and can replace existing worn, broken, or faded trim pieces that cost around $240 US retail for 2 rings.
This item DOES NOT INCLUDE boot/gaiter, shift ****, or beige fastening cap seen in photos. Only the multi-tab ring is provided.
The cupholder rings DO NOT INCLUDE the rubber gasket; thus, the old one should be saved.
Shift Boot Trim Ring Fitment vehicles as per REALOEM:
MINI R56 (10/2005 08/2010)
MINI R56 LCI (03/2009 11/2013)
MINI Clubman R55 (10/2006 07/2010)
MINI Clubman R55 LCI (03/2009 06/2014)
MINI Cabrio R57 (10/2007 07/2010)
MINI Cabrio R57 LCI (04/2009 06/2015)
MINI Coup R58 (12/2010 05/2015)
MINI Roadster R59 (01/2011 04/2015)
Can be used in applications, for example
25112753783
Buyer can use as is or prime and paint.
NOTE:
Pressure should be applied so the boot clips enter the receptacle evenly.
While this adapter is made from similarly rigid material as the OEM (CF-ABS: carbon fiber ABS plastic), clips will break if they are not aligned with the receiving slots in the console. Ensure the clips are "clocked" correctly.
It is difficult to remove the item from the topside after it's inserted into console, so, plan accordingly or remove the clips from the bottom side of the console.
Cupholder Rings (51162756163) fit the following per REALOEM:
MINI R56 (10/2005 — 08/2010)
MINI R56 LCI (03/2009 — 11/2013)
MINI Clubman R55 (10/2006 — 07/2010)
MINI Clubman R55 LCI (03/2009 — 06/2014)
MINI Coupé R58 (12/2010 — 04/2015)
MINI Roadster R59 (01/2011 — 04/2015)
