Replacement Shift Boot/Gaiter Trim Ring (3D-Printed)
Interior/Upholstery
  • Interior/Upholstery - Replacement Shift Boot/Gaiter Trim Ring (3D-Printed) - New - All Years  All Models - Holt, MI 48842, United States
    $25
  • Location Holt, MI, 48842, USA
  • Condition New
Shift Boot Trim (front console) - the item listed here is still available; see Outmotoring.com for more product.
Other colors (red, grey, blue) are coming soon.
(NOTE: This is NOT the smaller diameter trim piece for the front cupholder (51162756166))
This piece is typically part of an assembly, such as (25112753783), costing between $98 and $130, and is commonly broken when removing the boot/gaiter to change the shifter **** or linkage.
Based on RealOEM: Compatible Years and Models
MINI R56   (10/2005 — 08/2010)
MINI R56 LCI   (03/2009 — 11/2013)
MINI Clubman R55   (10/2006 — 07/2010)
MINI Clubman R55 LCI   (03/2009 — 06/2014)
MINI Cabrio R57   (10/2007 — 07/2010)
MINI Cabrio R57 LCI   (04/2009 — 06/2015)
MINI Coupé R58   (12/2010 — 05/2015)
MINI Roadster R59   (01/2011 — 04/2015)
3D-Printed from PAC12-CF (Carbon Fiber reinforced Nylon), annealed at 80 C for 6 hours.
Buyer can use as is or prime and paint.
NOTE:
• Pressure should be applied so the boot clips enter the receptacle evenly.
• While this adapter is made from similarly rigid material as the OEM (CF-ABS: carbon fiber ABS plastic), clips will break if they are not aligned with the receiving slots in the console. Ensure the clips are "clocked" correctly.
• It is challenging to remove the item from the topside after it's inserted into the console, so, plan accordingly, or remove the clips from the bottom.
https://www.ebay.com/itm/167140729203 (NO LONGER AVAILABLE on eBay until more stock is available, Look to Outmotoring.com for this product)
Includes Orientation Mark - These are still available on eBay.
MINI Cooper Shift Boot/Gaiter Trim for 25117624269/70/71/72, 25117605282 -Marked | eBay
