R53 (06) Piston Installation Question
Old Oct 26, 2024 | 02:26 PM
Planewizard's Avatar
Planewizard
Folks, I'm rebuilding an R53 - "stock". I marked the pistons when I took them out, and I noticed they have an "F" marked on the piston skirt. All the pistons "EXCEPT #1" have the "F" mark towards the forward side of the engine (front of car), But #1 was reverse...... After installing the rings, should I reverse the "F" mark to face forward?? These are stock, original pistons as best as I can figure?? I'm not building a race engine, just a reliable, get around town engine that won't burn oil. HELP!!
Old Oct 27, 2024 | 11:40 AM
mrbean's Avatar
mrbean
Ignore the F. There should be a small arrow stamped on the top of the pistons. All arrows should point towards the timing chain.
Do not mix up the bearing caps - they are a matched set with their respective con rods.
Old Oct 28, 2024 | 07:23 AM
bahman's Avatar
bahman
The piston skirts have cut-out on one side to accommodate oil squirters when pistons are at the bottom of stoke. The F or arrow markings are to ensure alignment of cut-outs with squirters. A mis-aligned piston (F or Arrow pointing toward flywheel) will collide with its oil squirter and cause damage.
tcbrady
Nov 8, 2021 10:22 AM
Boogers
Jul 23, 2021 06:54 PM
LAMiniMe
Jul 1, 2020 06:59 PM
MINI_chili
Nov 28, 2008 01:51 PM
