R56 Valve stem seals?
Old Jul 6, 2024 | 06:23 PM
Gerles305's Avatar
Gerles305
Valve stem seals?
Hi, I’ve got a 2008 mini cooper base (1.6) and I think it has a valve stem seal issue in the engine. When firing the car up after it sat for some time it will have blue smoke come out the tailpipe and it goes away. This also happens when stopping and accelerating again. I don’t think piston rings are the issue as the car has good compression, no blow by, and no loss of power. Also the plugs had oil on them when I took them out. I also did a piston soak to free up carbon and this did not change the oil consumption. Car has 155k miles. Would anyone agree with my assumption?
Old Jul 7, 2024 | 07:08 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
What were the exact cylinder compression numbers? Did addition of some engine oil to the cylinders substantially increase compression?
Old Jul 7, 2024 | 10:21 AM
Gerles305's Avatar
Gerles305
Each cylinder had over 210psi and I did the test when the car was already warm. Plugs were also wet with oil on all cylinders so I would say oil could’ve affected the results.
Old Jul 7, 2024 | 11:01 AM
Maybe, maybe not
Community Builder
Is the PCV diaphragm functioning properly, that is properly venting the crankcase?
Old Jul 7, 2024 | 11:04 AM
Gerles305's Avatar
Gerles305
Yes, replaced the valve cover
Old Jul 7, 2024 | 11:06 AM
Maybe, maybe not
Community Builder
Worn valve stem seals seems to be the best fit.
eastcoast56
Nov 21, 2022 11:21 AM
2011clubman_justa
R55 :: Clubman Talk (2008+)
Oct 30, 2022 12:17 PM
Jerry Phan
Sep 13, 2018 06:07 AM
ressler
Feb 19, 2013 10:49 AM
89AKurt
Nov 21, 2010 07:14 PM
