R50/53 Driver Window
Old Jun 20, 2024 | 11:14 AM
tbrin1's Avatar
tbrin1
Driver Window
So I thought changing out the driver-side window regulator would solve my issue with the window not going up or down.
It has not. I tested the motor before I put the new regulator back in the door. The motor turned as it should.
I reinstalled everything and pushed the switch, you could hear the motor turning but the window was not going up or down.
Open to suggestions as to what is going on.
06 Mini
Thanks,
Old Jun 20, 2024 | 11:54 AM
If its the motor the gear could be stripped and just spinning.
Old Jun 20, 2024 | 12:03 PM
tbrin1's Avatar
tbrin1
I thought that also. When I tested the motor outside the regulator the outer gear was turning. Unless the interior gears are stripped enough they can turn the outer gear but under stress, it only spins internally.
Will have to take it apart and dig a little deeper.
THanks for the response.
Old Jun 20, 2024 | 02:02 PM
ssoliman's Avatar
ssoliman
ive had good luck with these folks
https://www.allmagautoparts.com/prod...b3905d57&_ss=r
Old Jun 20, 2024 | 06:09 PM
noodlesandsam's Avatar
noodlesandsam
+1 on Allmag. I got a whole assembly.
Old Jun 21, 2024 | 04:19 AM
tbrin1's Avatar
tbrin1
Thank you.
I'm going to take out the regulator and motor and see what is going on in the inside of the motor.
Appreciate all the feedback. worse case, I'll order another regulator with the motor.
Thanks,
Old Jun 21, 2024 | 08:51 AM
cooper48's Avatar
cooper48
Buy a regulator with the motor installed. Attempting to replace just the motor is a real PITA. Don't ask me how I know.
exocet
Nov 19, 2013 10:40 AM
C-Lop
May 28, 2009 12:51 AM
mach21andy
Mar 30, 2008 02:15 PM
SammamishMini
Jun 12, 2006 05:47 AM
