R55 Vacuum pump types
Old Dec 23, 2023 | 10:45 PM
Sorcerer33's Avatar
Sorcerer33
Vacuum pump types
I have just received a new vac pump for my non turbo 2008 Clubman. The new pump has a small brass nipple as well as the larger plastic connector that the vac hose connects to. The existing vac pump just has the vac line connection. Did I order the wrong part?? is there 2 different pumps? Can I blank off the small brass nipple and use the pump anyway?
Old Dec 27, 2023 | 02:05 PM
Hello,
This is the one you need and oem MINI part number. I would get that one and return the other.
https://www.ecstuning.com/Search/Sit...h/11667570813/
Brian715
Nov 21, 2020 07:01 PM
cjmann1
Feb 2, 2018 12:19 PM
ig109
Jan 25, 2018 02:54 PM
Jckol
Dec 29, 2016 08:52 PM
TheProfessor971
R55 :: Clubman Talk (2008+)
Feb 20, 2015 01:33 PM
