Need help to see if there is a way to remove the metal piece that was left behind when removing the crank pully . Left a Pic any advice would be greatly appreciated.
I'd suggest a bearing separator in conjunction with a standard hub puller. The separator installs between the TC cover and what remains of the crank pulley.
The puller bolts into the two holes in the separator. https://www.autozone.com/transmissio...ring+separator
