R56 help with headlight alert (chime/warning light)
Old Sep 24, 2023 | 05:32 PM
tarheelblue's Avatar
tarheelblue
there. We recently bought my son his first car. It’s a 2009/10 S. Camden edition.
he loves it and I occasionally sneak a ride in it too. Loads of fun
The headlight warning light comes on when you start up the car and it makes its cute little chime. but the problem is throughout the ride (every five - ten minute?) or so it sends off the same warning.
I am trying to figure out if there’s a way to disable the alerts….at least the chime so it doesn’t go off during the ride to tell us about the headlight. if not…then root cause it and address. it gets to be quite a pain in the butt hearing that thing go off every few minutes. and more so it just is kind of a stressor for a new teenage driver
There is in fact nothing “wrong” with the headlights. I have a feeling that since they’re aftermarket xenon headlights the prior owner put in that may be for some reason they’re not playing nicely with the wiring and or setting off a false alert? like maybe they pull more power or something then the OEMs? There’s also aftermarket LED side marker lights. I don’t want to have to start taking stuff off the car and going to the trouble of having to find original OEM parts to put back in there just to get the warning light and chime to go away but if that’s the only solution then we can…
Anyone have any thoughts on why this alert may be getting triggered periodically during the ride? And are there any ways to address it even if just a workaround like disabling they headlight alert? Or more importantly the related chime? Or is there some sort of chime off feature or chime volume feature where we could just turn it down as low as possible?
thx
Old Sep 24, 2023 | 06:12 PM
mkov608's Avatar
mkov608
Yes there is a way to get rid of the burned out bulb warning; it requires a laptop, special software, a special cable, and some training on how to code the footwell module.
The module is looking for a specified resistance through the light bulb, so with aftermarket lights (LED bulbs etc) the module doesn't see what it's expecting, so it illuminates the light.
Old Sep 25, 2023 | 06:12 AM
tarheelblue
follow up
OK cool. That’s sort of what I was thinking and what I was hoping to hear. The aftermarket headlights are really bright which I like because I have a teenager and he has to drive home from work at night. So I didn’t really wanna have to take those out and go back to OEM just to get a warning signal to go off. The LED side lights I’m less concerned with and if I had to take them out I could. I guess I’ll try to find an independent Mini shop or maybe even a mobile mechanic that would be able to code for this. Sounds like it’s pretty basic if you have the software in the know how. Thanks again!
Old Sep 25, 2023 | 09:27 AM
mkov608's Avatar
mkov608
Most independent BMW/MINI shops will know how to turn the "bulb out" warning off.
Old Sep 29, 2023 | 06:14 AM
allenm324's Avatar
allenm324
Can't something like https://bimmercode.app/ or https://www.bimmergeeks.net/protool code out the voltage check? I have used Carly to code out the fog light and side marker voltage checks.
Old Sep 29, 2023 | 11:35 AM
hndle's Avatar
hndle
Yes. Bimmercode can set LED conversion to "active". When I first go my MCS, the first time I drove at night, got the error for the Fog's, yet they were working (!?).
The PO had converted to LED.
(YMMV)
SCountryMAN
Mar 28, 2020 07:31 AM
Pcoop
Dec 20, 2013 06:44 AM
ekh2000
Aug 22, 2012 07:05 AM
PaulWalliDumali
Electrical
Jul 6, 2010 06:03 AM
MINI Jackpot
Jun 28, 2007 11:39 AM
