R56 thermostat-housing leaking at 32K miles!
Old Sep 9, 2023 | 02:55 PM
GsxR1000's Avatar
GsxR1000
2009 Mcs 6MT with 190K miles on the clock
Out for a drive and noticed coolant temp spike to 130DegF. I monitor coolant temperature with a scangauge-ii like a hawk and normal operating for my car is 220-225DegF. As luck would have it, i was less that 1 mile for my home, so I go directly home, pop the hood and Bam, large pool of coolant on top of transmission.
Ugg, Pos Mini cooling system with it's plastic thermostat-housing and plastic water-pipe is a total PITA. If I didn't enjoy driving this thing as much as i do, it would have been scrapped long ago.
Anywhoo, ordered new Mini OE thermostat-housing and water-pipe. When I removed existing leaking Mini OE thermostat-housing, that I installed myself 32K miles ago, I noticed that the thermostat-housing gasket was flat, barely protruding out of it's groove on the the thermostat-housing. I assume this was the cause of the leak.
On a whim, I decided to obtain a fel-pro thermostat-gasket (Part #: FPG 35922) so I could compare it with the OE Mini gasket on my new thermostat-housing. Over all dimension was the same however, the fel-pro gasket was noticeably more dense, much harder to compress/squeeze than the Mini OE gasket. So, I elected to install the Mini OE thermostat-housing with the fel-pro gasket. Existing water-pipe looked fine. Probably could have re-used it but, why take the risk. I always replace both even if only one is leaking.
Also fwiw- I use silicone grease on water-pipe o-ring (that goes into block behind water-pump), on the thermostat-housing o-ring (that goes into water-pipe), and a little on the thermostat-housing gasket. Makes for a smooth 'snick into place', installation. I also use a laptop w/ a usb video scope camera to view inserting water-pipe into rear of block behind water-pump so I don't have to remove the intake.
Hopefully, this thermostat-housing installation will make it past 32K miles.
Cheers
Old Sep 14, 2023 | 07:01 PM
texasmontego's Avatar
texasmontego
I've had so many issues with the coolant system on the R56. It just doesn't last very long and I've learned (painfully so) there is a definite quality difference between thermostat and water pump manufacturers. I'll be going with the metal water pipe from ECS anytime I do them again. I've seen so many pipes fail within a short period of time by cracking around the O-ring on the water pump side. It's just very frustrating, but you're right, if they weren't so damn fun, I would have drove it off a cliff.
Old Sep 15, 2023 | 07:17 AM
R53148FW's Avatar
R53148FW
Your "failures" in your signature made me laugh so hard
Old Sep 15, 2023 | 08:50 AM
GsxR1000's Avatar
GsxR1000
Just keeping it real :-)
I'll have to update my failures list to include wheel bearings, one just started howling. In process of sourcing replacement wheel bearing now... lol
Old Sep 15, 2023 | 09:02 AM
R53148FW's Avatar
R53148FW
I've been on the brink of giving up on our R56 but for some reason I cant bring myself to give up
Old Sep 18, 2023 | 10:59 AM
I have the metal pipe and new thermostat and all good. Just on my second thermostat with about 138K on the R58 JCW. My original thermostat went at like 80-90k had the bremmen parts thermostat so far and its been on and off a bunch of times testing prototypes all the time on my car.
frankiev
Jun 26, 2023 06:44 AM
amusable
Nov 17, 2019 10:42 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
banyan
Sep 3, 2014 12:55 PM
mrheeee
Dec 29, 2013 10:14 PM
