R50/53 Clutch Line O Ring Size?
Old Jul 24, 2023 | 01:12 PM
John Norse's Avatar
John Norse
So I'm tracking down some funky clutch feel issues and decide to go ahead and spring for a new slave and master cylinder first to eliminate those two factors on a fairly high-mileage R53. It supposedly got a new clutch before I bought it, so I'm reluctant to jump straight into that job without doing the simple stuff first.
I bought a Sachs master cylinder and the fitment is just kind of sloppy for the 90 degree elbow that mounts into the rear of the master cylinder. The previous unit is snug-ish but was not leaking. Everything was bone dry before I fixed what might not have been broken. I put a little fluid into the reservoir and let it sit overnight and sure enough the joint is leaking with no pressure on the system.
I have had bad luck in the past just taking an o-ring to the local auto parts shop and trying to match it up. They don't have any metric o-rings on hand typically. I could order the line coupling for basically 50 bucks and wait a week and a half, but I would much rather just sort the o-ring if possible. Any idea if there is some sort of secret data-base of these o-ring sizes somewhere? Real OEM just gives me the line part number, no specs on any seals.
Old Jul 25, 2023 | 02:21 AM
Xplct's Avatar
Xplct
When you bleed the clutch, make sure you do it with the slave cylinder fully pressed in with a clamp system, otherwise you will have a hard time getting the air fully out, the bleed screw and inlet are too close together.
Even with a power bleeder, it didn’t work until I did this.
Old Jul 31, 2023 | 04:43 AM
Daftlad's Avatar
Daftlad
Has this been resolved? Did you find a matching O ring at the local store or online?
idickers
Apr 2, 2023 02:28 PM
Brandon Fluharty
Jan 12, 2022 09:02 AM
AngryScotsman
Sep 6, 2019 06:12 AM
EdSmelly
Jul 14, 2013 10:28 AM
sprint1126
Jun 23, 2013 12:40 PM
