R56 Trying to Solve Codes P0597 & P0503
Old Feb 16, 2023 | 04:13 PM
itsRambally's Avatar
itsRambally
Good Day R56 Owners, trying to trace down these codes to find out what I need to fix/get done.
I know they are kind of generic but I know P0597 has to do with the cooling system and P0503 has to do with Speed sensors.
Where should I start to get these codes out?
Old Feb 17, 2023 | 07:15 AM
white46's Avatar
white46
P0597 -> replace thermostat
P0503 -> not totally sure what needs to be done, but you are right, it's something to do with ABS sensor or DSC module
Old Feb 17, 2023 | 07:28 AM
RockC's Avatar
RockC
This link may be of some help to you:
https://www.obd-codes.com/p0503
Old Feb 17, 2023 | 08:37 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Yes, thermostat needs to be replaced.
For the second code, could be a bad wheel speed sensor or connection. I would start by getting the car in the air and checking all the wheel speed sensors to make sure the wires aren't broken, check connectors to make sure they are plugged in, and then check that none are corroded.
Old Feb 17, 2023 | 06:46 PM
CakeEater's Avatar
CakeEater
Okay idk how I got so sucked in and read the whole thing, but I feel a little bit smarter. I can sleep happy tonight.
Thank you.
potzer
Jul 29, 2022 09:35 AM
bmcgough
Dec 19, 2021 10:33 AM
ZRXChris
R55 :: Clubman Talk (2008+)
Nov 14, 2019 04:51 PM
NashvilleMiniStan
Mar 14, 2010 07:47 PM
