2005 Cooper S - Track Inspired
2005 Mini R53: "Mk I" Mini Cooper S
  • 2005 Mini R53: "Mk I" Mini Cooper S - 2005 Cooper S - Track Inspired - Used - VIN WMWRE33485TD92546 - 99,200 Miles - 4 cyl - 2WD - Manual - Coupe - Silver - Temecula, CA 92592, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
    $13,000
    • OBO
  • Location Temecula, CA, 92592, USA
  • VIN WMWRE33485TD92546
  • Mileage 99,200
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Coupe
  • Exterior Color Silver
 Bought 3/2020 - 84,000
 Work done:
Valve cover gasket
Oil pan gasket
crank position seal
Front main seal
Rear main seal
OEM clutch with single mass flywheel
AC delete kit
All new radiator hoses
New thermostat
Supercharger oil service
New water pump
New knock sensor
New speed sensors
Poly urethane motor mount inserts
Front control arm power flex bushings
New front ball joints
New intercooler boots
New belt tensioner
Short throw shifter
 Engine mods:
dyno tuned @ 210hp/185tq (proof of dyno)
15% WMW pulley
0% lightened Cravenspeed crank pulley
Newman PH2 cam
450cc injectors
New OEM intercooler w/ heat dispersant
Custom high flow cat headers
Custom cat back exhaust
Custom air intake
K&N air intake
oil cooler Kit
 Suspension:
Koni dampening adjustable shocks
22mm rear Eibach sway bar
Alta adjustable front and rear endlinks
Power flex bushings - control arms and motor mounts
Brandless front strut tower brace
 Brakes:
4 piston Wilwood brake kit
Wilwood Street and race pad sets
EBC rear street rotors and pads
Have OEM front brakes with slotted and drilled rotors.
OEM and race brake pads for stock calipers
 Exterior:
Paint is faded on hood.
Roof has scratches
Custom carbon fiber racing stripes
Fender flares
Custom Wing
 Interior:
Rear seat deleted (still have complete set)
Short throw shifter
Sparco seats with sliders
Oem seats (blue&black leather)
Radio doesn’t work. Or the speakers don’t work. Turns on but no sound.
 Wheels:
17x8 Motegi MR157 CM8
(23lbs per rim) - 1000miles on rims
Falken Azenis 615k tires - approx 1000 miles on them
OEM wheels with Bridgestone potenza tires as well
 If you buy the car for my asking price, I will throw in all the extras I have. If you want cheaper, Motegi rims and Wilwood brakes can be removed to save $$$$.
