how do I check if my timing chain has an issue or not? (photos)
Old Jan 13, 2023 | 12:43 PM
badafada's Avatar
badafada
Hi all, I'm in the process of replacing various things, and already have the intake off and the valve cover off, so I see my timing chain - but is there a simple way to check if the chain is not "stretched"?
Of course if the chain needs replacement I would like to go ahead and do it now, but also I don't want to do it if I'm within acceptable limits.
I do see half of the guide cover broke off on top (didn't see any of those parts floating around anywhere).
video:
Old Jan 13, 2023 | 12:52 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The proper way to check for chain stretch is with the special tool, the one on the left in this picture:
The tool is installed in place of the tensioner, then you remove and measure the tool length.
Old Jan 13, 2023 | 12:54 PM
badafada's Avatar
badafada
thanks @njaremka I'll order this tool
Old Jan 13, 2023 | 05:44 PM
badafada's Avatar
badafada
I figured I might as well change the chain, so I ordered this kit from detroittuner: https://www.detroittuned.com/mini-n14-timing-chain-kit/
It's a cryotreated chain so hopefully it will last the rest of the car's life. I guess I got confused with the terminology because I saw a video showing a piece called the "pretensioner" to test the chain wear.
Old Jan 14, 2023 | 05:09 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The “pretensioner” is that tool. If you haven’t already, be sure to purchase the full timing chain tool set.
Old Jan 14, 2023 | 06:46 AM
badafada's Avatar
badafada
Thanks @njaremka I did purchase that too. I'm wondering now if I might as well do the head gasket at this point - how much more work is it? I haven't found a video online showing the full process for S cars, only the non turbo.
Old Jan 15, 2023 | 03:42 PM
CakeEater's Avatar
CakeEater
Check out this video, i just did the chain on my N18 and this helped so much
kat1689
Jan 27, 2020 11:58 AM
Xjsf28
Sep 21, 2019 11:53 AM
BushOner
Jul 16, 2014 02:49 PM
Bobbyn
Jul 21, 2009 10:21 AM
