proper way to completely reset the ECU?
Old Dec 17, 2022 | 09:32 AM
badafada's Avatar
badafada
Hi all, I want to know if these is a BMW documented procedure for MINIs for completely resetting the ECU?
I have an R57 and R55, though I'd imagine procedure would be the same for both.
I understand you could disconnect the battery completely, but there are still capacitors in the car - how long would it take for them to lose all power? You could touch the positive and negative leads together after disconnecting battery, but I wanted to make sure thats safe to do or if the fast capacitor discharge from doing this would hurt anything.
Old Dec 18, 2022 | 02:29 PM
RockC's Avatar
RockC
Disconnecting the battery would be the best way. I'd not short the positive and negative cables together. If one of the cabin doors is open that would/should have some interior light on and that drains any residual power. You could turn on the emergency flashers too I think. They work or should work even if the engine is off, the ignition is off.
Or you could just disconnect the battery and wait...
A problem with disconnecting the battery is the connecting it again. If you fumble this you can power glitch the electronics and that can bring about possible issues that of course can be addressed by another battery disconnect.
Old Dec 19, 2022 | 06:04 AM
badafada's Avatar
badafada
thanks @RockC that makes total sense I don't know why I didn't think of leaving a light on or door open.
Anyway I've already replaced the battery and a majority of the codes went away, now I only have 18 real codes instead of 62! Ha.
Old Dec 19, 2022 | 07:28 AM
RockC's Avatar
RockC
Some codes -- but 18 is a lot more than I would expect -- will go away as you drive the car. I remember with one car with a steering wheel/angle sensor after I changed the battery and brought the bad battery back to the dealer a tech offered to reset this sensor for me. But the warning message had gone away before I even reached the dealer.
Some codes -- these are called permanent -- can only be cleared by the engine controller after so many warm up cycles with the error absent. Some take just 3 warm up cycles. Some take more.
Old Dec 19, 2022 | 07:35 AM
badafada's Avatar
badafada
Yep - there was a lot because I bought it as salvage title. It was in an accident but I saw the photos and it wasn't bad. Car drives great but most of the errors are related to the airbag system needing to be reset (rollbar sensor, pretensioner, that sort of thing)
Old Dec 19, 2022 | 09:07 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Inpa.. if you have a laptop inpa is a must have for any mini owner..if you unfamiliar with it , just Google it.. alot of good info there and northamericanmotoring.com also on it.
Old Dec 19, 2022 | 10:17 AM
badafada's Avatar
badafada
Thanks @MiniManAdam . is INPA the same as ISTA? I'm actually in the processing of setting up ISTA software now
Old Dec 19, 2022 | 01:47 PM
MiniManAdam
Community Builder
I belive so yes... if you need help with it I'd advise pm'ing adriancl , hes a wizard. He helped me a ton, without him ? Geez , my car wouldn't be half of what it is..
Here2Go
May 30, 2026 11:23 AM
rob.james.arias@gmail.com
Jan 8, 2016 09:27 AM
harhoosh
Jan 23, 2007 08:50 PM
tradiuz
Dec 1, 2005 08:26 AM
Messore
Feb 2, 2003 07:14 PM
