Motegi Racing TrakLite 1 Gunmetal Forged Wheels
Wheels and Tires/Axles
  • Wheels and Tires/Axles - Motegi Racing TrakLite 1  Gunmetal Forged Wheels - Used - 2002 to 2006 Mini R53: "Mk I" Mini Cooper S - Indio, CA 92201, United States
    $325
    • OBO
  • Location Indio, CA, 92201, USA
  • Compatibility
Make Model Year
Mini R53: "Mk I" Mini Cooper S 2002 - 2006
Set of 4 Motegi Racing TrakLite 1 wheels.  Super light weight at 6.6KG or 14 lbs 5 oz per wheel. About 1/2 the weight of  the OEM wheels.  They have been used exclusively as the second set of wheels for my track only R53. These are forged wheels so are lighter and stronger then cast.  They have curb rash and discolorations. But they run true, and when tires are mounted hold air without any leaking.   These are perfect for track or autocross use.
Brand:Motegi Racing Performance Wheels
Product Line:Motegi Black Trak-Lite Wheels
Wheel Diameter:17 in.
Wheel Width (in):7.000 in.
Wheel Material:Aluminum
Manufacturers Wheel Series:Motegi Trak-Lite Series
Backspacing (in):5.625 in.
Offset:+42.00mm
Wheel Construction:1-piece
Lug Nut Seat Style:Conical seat - 60 degree
Wheel Bolt Pattern:4 x 100mm
These fit OEM calipers and if the car isn't lowered too much should fit the fenders. My Mini has StopTech  Big Brake ST-40 calipers and rotors in the front and these wheels fit with one small spacer.
They will ship in  fully protected Enkei wheel  boxes.  Weight is 17.5 lbs per box dimensions 10x19x 11
Wife wants these out of the garage. Reasonable offers welcomed.
Old Dec 7, 2022 | 12:15 PM
mudbuddha's Avatar
mudbuddha
You have pm. thanks !
