R50/53 Help me pick my clutch and decide which lsd , winter mods begin!
Old Nov 17, 2022 | 05:05 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I will list my cars modifications at the end so you know why I'm want the spefic parts I do..
​​​i need help picking out parts and if someone could give me a parts list such as which gaskets ect will need replacing ect plz post up.
I don't wanna do the valaeo conversion because I have my personal reasons and I've been advised to look into another option.. I've used an ebay clutch befor and it worked amazing for that car but that car was not a mini so does anybody have any feedback on one theve used ?
I wanna get a lightweight flywheel ( 14lb-17lb) and a stage 2x clutch. I know I will loose alittle driviability in stop and go traffic but that's completely fine as my car is an occasional driver / weekend warrior.
my cars current clutch and transmission have 0 issues but I feel like the clutch is getting pretty stiff so I wanna take this down time over the winter to do some more upgrades and this is the start if it all.. here are the 2x lsd's I have been looking at as well as the clutch I feel would suit my needs.
im also looking at budget minded clutchs becauseid like to invest in new gaskets such as oilpan gasket and new balljoints and ac delete pulley and new belt. Heres my mods and then the links to the parts i been eyeballing. Mods list is below parts links because its lengthy
https://www.ebay.com/itm/152990599821?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=63akh65fR-a&sssrc=2349624&ssuid=At-wg-DKQu2&var=&widget_ver=artemis&media=COPY
https://www.ebay.com/itm/295290325612?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=kdnrbpy9q3y&sssrc=2349624&ssuid=At-wg-DKQu2&var=&widget_ver=artemis&media=COPY
https://www.ebay.com/itm/143642533038?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=gSJa0stbTyS&sssrc=2349624&ssuid=At-wg-DKQu2&var=&widget_ver=artemis&media=COPY
ENGINE :
. Tpr2 big valve head
. Ns1 street cam
. Gen2 Sprintex supercharger with 60mm pulley and vented fill plug ( 21psi )
. Snow stage 2.5 methanol kit WITH extras
. 2% light weight crank
. Fully ported sneedspeed Manifold
. Obx 421 catless headers with ported flange and nvida resonated exhaust ( passes emissions)
. 550cc bosche fuel injectors
. High-flow fuel pump and new filter
. nology hotwires and ngk 1x step colder plugs
. ported stock throttlebody and custom 3in intake with 6in velocity stack cone filter
. grs motorsport intercooler
. Aluminum coolant and clutch fluid reservoirs
. M7 aerogel heatshield and custom intake heatshielding
. Mishimoto aluminum radiator and 180' thermostat
. Detroit tuned bypass valve
. Ported and shaved intercooler horn also tapped for the methanol
. Upgraded silicone coolant hoses and upgraded vacuum lines
. Upgraded intercooler boots
. Remote activated intercooler sprayer system ( button on steering wheel and uses rear wiper reservoir)
. Custom tuned with tuning software and laptop. 2x tuned ecu's. One for methanol one for without.
. Oil catch can
. Carbonfiber hydropdipped valvecover
SUSPENSION ,STEERING & BRAKES :
. R56 brake swap , ebc redstuff pads and brembos rotors with stainless steel lines and high-performance dot4
. rev9 hypersteet2 coilover with caster camber plates
. Front adjustable control arms
. Front and rear adjustable swaybar end links
. Rear upper and lower adjustable control arms
. Vip engine brace
. Performance lower transmission mount
. Polly filled or polly replaced stock bushings all throughout the vehicle
. Carbonfiber Front and rear strut bars
. Convertible support braces
. 16x8 lightweight rims ( 16lb) , 5mm spacers and extended lugs with 205/45 firehawk indy 500 tires with around 5k miles on them. They fill out the widebody flares well. I also have the stock rims with good tires on them..
INTERIOR AND EXTERIOR MODS :
. full bodywork and nardo Grey paintjob done in april
. Coolerworx shifter and facelift shift cables and new transmission shift bracket and weights
. Euro parcel shelf
. Tablet running torque plus for gauging and performance monitoring and multimedia. ( wasn't installed during video)
. Rally lights running off a toggle switch
. Jcw shift light
. Custom rear seat delete, setup for under neath storage and hides injection pump and lines ( I still have the perfect condition stock rear seats ect )
. Fiberglass widebody fenders
. Carbonfiber steering wheel with remote activated intercooler sprayer button.
. Carbonfiber look hood vents
. Carbonfiber look side skirt/flares
. Carbonfiber side mirror covers
. Carbonfiber rear vents scoops for real cold air intake and brake master cooling
. Carbonfiber C-pillar aero panels
. Carbonfiber leap v3 hoodscoop and carbonfiber air diverter
. Carbonfiber dash
. Carbonfiber hydropdipped parts that could not be purchased as real Carbonfiber.
. Carbonfiber wrapped downtubes
. Carbonfiber vinyl overlay over many other interior parts
. Carbonfiber door handle covers
. Carbonfiber gascap cover
. Carbonfiber adjustable spoiler
. Carbonfiber exterior pillars
. Carbonfiber boot lid trim
. Carbonfiber ebrake handle
. Carbonfiber look chrome delete
. aero style bumper lip
. Real custom 3d printed rear bumper vents ( with leds behind them)
. Leap rear Fiberglass diffuser
. Led Unionjack turn signal markers
. Led halo bumper running lights
. Led halo headlights and carbonfiber trims
. Led smoked sidemarkers
. Led smoked foglights
. Led smoked taillights and carbonfiber trims
. Leds in wheel wells ,front grill , hood scoop and rear bumper vents are are illuminated.
. Led color changing programable interior lighting
. Snow boost gauge / controller
. Afr gauge and wired in wideband sensor
. Fully adjustable racing seats on sliders
. Custom installed armrest
Old Nov 18, 2022 | 05:07 AM
Daftlad's Avatar
Daftlad
>No carbon fiber ash tray
What are you an originalist?
Old Nov 18, 2022 | 05:33 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Certain tasks you only want to do once. Swapping out a clutch, and installation of an LSD on a Mini fall into this catagory. I would steer clear of the Ebay stuff for this reason.
I would go with this flywheel:
https://clutchmasters.com/i-30500875?q=
This clutch:
https://clutchmasters.com/i-30497915?q=
And this LSD:
https://www.waymotorworks.com/quaife...ferential.html
I did the Clutchmasters FX100 kit in my stage 2 Clubman, and I've been very happy with it. Streetable, and zero slip on full power. The clutch I picked for you is their FX300 kit, which should give you a bit more bite. Also, the aluminum flywheel will make the engine super responsive.
For LSD, I went with the MFactory, and I wish I had splurged a little bit more for the Quaife, only because the Quaife is popular in the UK. With a mechanical LSD, maintenance will also be very low. Change the gear oil every 25,000 miles, and rock-n-roll.
Old Nov 18, 2022 | 11:24 AM
MiniManAdam
Community Builder
This clutch:
And this LSD:
could you re-link the parts , I couldn't open the links or copy and paste..
also can you tell me what the advantages of the qualifiqualfie v the getrag are?? They look like the exact same piece and specs from what I could find are the same..
I'm really not looking to spend that much on this job either or other things get looked over due to lack of money..
I will definitely consider a more expensive clutch and flywheel but my lsd have come down to the 2x I've posted.
I 100% get not fully trusting Ebay stuff but Ebay stuff is either a hit or miss..and if it's 1/3 the price and warrentied , I absolutely have no problem trying it and if it sucks removing it,returning it and throwing In better name brand parts..
My time and labor is free so that's why I am willing to try budget oriented things 1st and if they suck , atleast I can advise others to not waste their time.. but to just say that because it's sold on ebay it sucks or isnt any good isnt fair.. wmw sells Certain things off ebay even as well as other vendors of this site and lol buying them off ebay can be cheaper sometimes because of free shipping..
but if I can get namebrand stuff for not too much more money and if it can fit in the budget, i absolutely would..but every dollar that can be saved here can be invested there..
Old Nov 18, 2022 | 11:25 AM
MiniManAdam
Community Builder
naaaaa , I may smoke but keeping old butts and ash inside a vehicle I NEVER do. Even though I smoke I rarely do in my mini and it's religiously cleaned. You can't smell one hint of smoke or anything.
Old Nov 18, 2022 | 11:34 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Just go to the Clutchmasters website and search for R53. I linked the aluminum flywheel and the FX300 kit to be sued with their single mass flywheel.
True, not everything on Ebay is crap, but I certainly wouldn't buy a clutch kit from Ebay. No telling WHAT you might receive. Also, I would sooner buy direct from WMW or other vendor, than through their Ebay store. Send my funds direct to the vendor, instead of giving a percentage to Ebay.
Old Nov 18, 2022 | 11:53 AM
MiniManAdam
Community Builder
ok I will check them out.. I'm sure the ebay wouldn't last as long either but if I could say get 5yr & 30k miles out of it. I would be happy.
Old Nov 18, 2022 | 02:18 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With that long list of parts and mods you've already spent a tone on the car. So cheeping out on important parts like a clutch and diff is like getting a date with a supermodel then taking her to McDonalds and hoping it works out.
For sure go with the Quaife LSD as they are by far the best and 100% reliable and why they come with a lifetime warranty. A diff failure is more than just replacing it as usually it will take out the trans with it when it fails.
As for the clutch pick your poison as race clutches are for racing, not daily use and won't last on the street.
Old Nov 19, 2022 | 02:17 AM
MiniManAdam
Community Builder
I was told to avoid the Valeo with my mods and power..I was told unless I wanna deal with non stop chattering and high boost slipping to avoid it so I'm going to follow that advice.. and this is advice is from 2x people who've both recently done the Valeo clutch conversion.
I'm leaning towards this act clutch as they are a very good brand from all ive ever heard and read... i will do somemore digging though..
but can anyone tell me what's the difference between the lsd I posted and the qulafie ?? Honestly, I swear they're the exact same thing ,one just has a few extra brandnames lazer etched on it...other than that I'm seeing abd reading no difference but I will try to find more technical info such as percentage of lockup or what ever I can find..
im gonna take your guys adviceand not cheap out on the clutch and flywheel..though i wish the act flywheelwas as light as the ebay ones can get ( 4-6lb difference) but maybe it's for a reason the better brand ones don't come with as light of a flywheel..I know a heavier flywheel can help drivability and all but light revs faster so maybe they know the sweet spot..idk , I wish more people posted up with results of aftermarket parts they use..
is the qufie lsd a helical style lsd ???
clutchmasters.com is screwing them selves , if they cant even keep their online site up and running i cant inagine how they deal with orders...geez ,how long can a site be down for ?
and i cant find the weight of the clutch masters aluminum flywheel or the act streeetlite steel flywheel , neither I can find the weight listing..I want the lightest of the 2x.
https://www.partsgeek.com/7n593gp-mini-cooper-clutch-kit.html
https://emnotek.com/products/act-streetlite-steel-flywheel-mini-s-r53
Old Nov 19, 2022 | 03:34 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The Quaife is a mechanical gear style LSD, so there is no lock up percentage. Lock up is only a factor with clutch style LSD. That’s why I recommended the Quaife, and the reason it needs no maintenance. The clutch style LSDs will need rebuilding after so many miles, whereas a gear style will not. The biggest difference between gear style LSDs are in how the internal gears are designed to transfer torque. I suggest watching a bunch of YouTube videos to learn how gear/helical LSDs work.
Old Nov 19, 2022 | 07:34 AM
MiniManAdam
Community Builder
thx but I'm aware of how they work and the difference.. this is why I keep asking what's the difference between the qualfie and the getrag. Theyre both helical design and everything else I see is the same too..
what I don't get is why one is 2x the price of the other one ? I'm trying to find whats making it so much more expensive, like is there something the getrag cheaps out on ? Idk but I'm determined to find out..
Old Nov 19, 2022 | 07:58 AM
MiniManAdam
Community Builder
So now I think lol I'm leaning towards exedy clutch kit , it's comes with the flywheel and everything..
I contacted partsgeek and they can't verify which flywheel I need to or can use with their act clutch soooo , they loose business my business then. Lol parts supplier that has no clue about the parts they sell , figures.
so if I can't find forsure whst flywheel I can use with the act clutch ille probably just buy this kit from m7 , it's alot more than i was looking to soend on a clutch and flywheel but you guys are absolutely rite. You get what you pay fir with a clutch and it's not one area I can chinse out on. Soooo looks like I'm going to need to sell a few more bmw v12 throttlebody kits in order to afford this. So them dang custom made intake tubes NEED to hurry up and get here..
https://www.m7tuning.com/mini-gen-2-fx300-clutch-kit
Old Nov 19, 2022 | 10:50 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
The ebay link you gave for the Tema4x4 place in Dubai is selling an NRF brand product, apparently made in Russia and little info to be found.
The other place is offering a Blackline brand product which is a made-in-china copy of the Quaife unit, and there's a good bit more info out there about it,
the most informative thread I found is this one on a Z4 forum:
https://z4-forum.com/forum/viewtopic.php?t=102831
Someone there even took a pic of it disassembled:
Help me pick my clutch and decide which lsd , winter mods begin!-qsfyhml.jpg
The buyer felt it necessary to disassemble because the unit needed de-burring,
so that's one area where the manufacturer deffo cheaped out in finishing quality.
Help me pick my clutch and decide which lsd , winter mods begin!-xpb1a9n.jpg
I'm in the Quaife camp as far as what I run and it has been headache-free, but I do understand budgetary constraints and there are other options out there, just a matter of research I reckon, trying to find enough positive reports to make you feel comfortable enough to gamble on the hope of it being just as good or whatever.
Old Nov 19, 2022 | 01:45 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I would steer clear of anything made in Russia right now, for obvious reasons. Also, China copies of legit products are a carp shoot for what you'll get.
Again, something like a diff and clutch, I'd rather spend a bit more and do it once, than cheap out and do it twice for more than the cost of the quality product.
Old Nov 19, 2022 | 02:38 PM
deepgrey's Avatar
deepgrey
You might say that finding terrible Chinese knock-offs is like shooting fish in a barrel.
Old Nov 19, 2022 | 07:13 PM
MiniManAdam
Community Builder
Just was offered a SCREAMING GOOD deal on a clutchmasters aluminum lightweight flywheel so soon as I can afford I will be ordering the 03050 hdkv d clutchmasters clutch to go with it then... I do appreciate you guys pointing me in the rite direction once again.. I'm sure ille be praising you once it's in..lol
anyways can somebody help me think of a parts list now for things I should and things I NEED to replace while the subframe is out.. I have no clue what internally the trans is gonna need new.. and btw unless the qulafie lsd goes on sale or I get a good coupon to use on one , chances are I'm going with the getrag lsd..
Old Nov 26, 2022 | 01:06 PM
MiniManAdam
Community Builder
1x if the 3x main things has arrived
Old Nov 26, 2022 | 01:15 PM
ssoliman's Avatar
ssoliman
Anyone try gripforce? I know these are popular in the BMW world
https://gripforceclutches.com/catego...oper/2005.html
Old Nov 26, 2022 | 04:59 PM
MiniManAdam
Community Builder
I will definitely keep this in mind.. I will do all I can to afford a quaife i will.. i will have to sell off the 3in intake setups i put together soon as they arrive.. if i can sell them befor i need to do this job i will be able to get the better lsd then too along with this better name brand clutch n flywheel. I'm also going to buy oem throw out bearing and seals along with the clutch fork thingy my buddy had mentioned..
Isn't it common to have some burrs and that's why you always change the fluid after 500 miles ? Atleast back in the day with the rwd cars I put together that was the case.. I'd used for racing 410 8.8rear end gear sets and that was typical of them..but again , better safe than sorry and I like the piece of mind knowing my cars solid.
that's a BIG reason I finally pulled the trigger on a gpr tensioner for my Sprintex sc..
Old Nov 27, 2022 | 04:09 AM
Daftlad's Avatar
Daftlad
>The bi-ped drops a purrfectly crisp new sleeping box in my living room
>Unexplained metal object inside it, in my way, very annoying
>Will humans never learn the proper order of things...
Old Dec 4, 2022 | 03:25 PM
Racingguy04's Avatar
Racingguy04
For what it's worth, I love my quaife. I bought it in 2020 when supply issues were a problem. I couldn't find one in the US, so I ended up ordering it from Orrange in the UK. I want to say it came with the bearings already pressed on, and you don't have to pay VAT. Between the VAT, the exchange rate, and not having to pay for the bearings, it turned out to be the cheapest option, and I want to say it took less than a week to get it into my hands.i paid $800 usd delivered
Old Dec 4, 2022 | 05:19 PM
cmt52663's Avatar
cmt52663
I've 60k on my Quaife and no regrets.
Sure extends the front brake life as well... ;-)
Cheers,
Charlie
PS: LSD = No eLSD
Old Dec 5, 2022 | 06:10 AM
MiniManAdam
Community Builder
lololol , YUP.. he thinks everything we do is for him..
I rearrange my living room and get the fireplace fixed n cleaned and setup for the wife to come home to as an early Xmas present and lolol , of course . Felix ( my cat ) is the 1st to lay RITE in front and claim his spot. Lol he also takes showers with me and when I feed our fish , he hangs his paws IN the tanks and reaches all the way in to swat at the fish. Hahaha ,he's only fallen COMPLETELY in 4x times sofar. But he likes water. Lol I tried using a spray bottle to keep him off counters and when I spray him , lololol he begins purring and trying to eat the water as it hits him like a dog.
Old Dec 15, 2022 | 11:41 AM
Soul Coughing's Avatar
Soul Coughing
Quaife is worth the money and time to install; it transformed my old '03 and is much better than the OEM one in my GP.
Old Dec 15, 2022 | 05:58 PM
MiniManAdam
Community Builder
I'm definitely keeping it in mind. If fund allow I firsure will.
