Key slot slide is stuck in the "in" position.
Old Nov 7, 2022 | 06:08 PM
jm348ts's Avatar
jm348ts
Just happened today on my 2009 Clubman JCW:
I tried to use my remote on the door but found that it did not work. I opened the door using the key in the fob. I found my other key in the remote start slot upside down. I must have left it in there overnight. Upon trying to remove it I found that it was stuck and it took some jiggling and pulling hard to get the key fob out. Problem now is that NOTHING works. There is no dash lights, no dome lights, nothing as if the car has no electricity at all.
Did i kill the battery with the upside down key in the slot overnight? Did I damage the key slot by pulling it out?
HELP!
RESOLVED: the battery happened to die at the same time so the key slot wouldn't release. Not sure if leaving the key in killed the battery but a new battery cleared everything up and back to normal.
Old Nov 8, 2022 | 06:42 AM
Might have killed it, " I found my other key in the remote start slot upside down" Key fob reader 61359299332 You had that in the slot upside down.
https://www.northamericanmotoring.co...n-t-start.html
tjkru
Aug 25, 2021 02:29 PM
Half_p1nt
Feb 2, 2019 06:33 AM
SemperMini
Nov 2, 2014 03:52 AM
DailyDrivenMini
Sep 11, 2012 10:58 PM
NaplesFL.MCS
Feb 28, 2008 03:51 PM
