R53 electric water pump adapter flange
Engine - Power Adders
  • Engine - Power Adders - R53 electric water pump adapter flange - New - 2002 to 2006 Mini Cooper - Huntsville, AL 35749, United States
    $50
  • Location Huntsville, AL, 35749, USA
  • Condition New
  • Compatibility
Make Model Year
Mini Cooper 2002 - 2006
Professionally welded Hose barb bung (leak tested).
Details:
Up for sale here is an unused Hose barb which was welded to a flange (off a 2006 R53 donor block).
Reason:
R53 water pump flange needs conversion for E (electric water pump) mod from stock; per DIY Electric water pump conversion (a write up exists here on NAM forum).
I was planning this mod and ended up selling the car! Been going through the garage and selling items that are no longer needed; my loss is your gain - because, this assembly is over 80 bucks! It cost me $40 to have it professionally shop welded (and their shop leak test). The bung cost $20 and the flange alone (worth the same amount) is around 15-20 bucks when shipped.
Note:
You will need the stock O-ring flange Gasket (not included) but readily available online.
This Ships for FREE via USPS Priority Post in USA only. Thx!!
