2006 MINI COOPERS R53 6 Speed Manual. NEEDS TRANS
For Sale2006 Mini R53: "Mk I" Mini Cooper S
Price
$3,500• OBO
- Location Delran, NJ, 08075, USA
- Condition Used
- VIN WMWRE33526TL19079
- Mileage 147,000
- Engine 4 cyl
- Drive Type 2WD
- Transmission Manual
- Vehicle Type Hatchback
- Exterior Color Red
Well loved Mini purchased from Senior original owner in 2019. All maintenance records. Show major engine work and
clutch replacement done by the dealer sometime in the past.
Currently, at about 147000 miles, was getting ready for repaint until something in the trans let go.
As a retired senior on fixed income, I unfortunately can't afford the repair. In the past I would have done it myself.
The condition of the car is very good. NO RUST. I started to remove the failed clearcoat Only a couple very minor dents.
The interior needs nothing. Leather is still excellent with very minor wear. Everything works.
Engine is excellent and very lusty, pulls cleanly to redline if asked to. No smoke, no tap. Milltek exhaust replaced the Borla and sounds perfect. Clutch action still feels perfect.
Good ride (for a Mini) and brakes. Cold Air. Excellent Continental Tires.
Other than the trans, no other issues to address. In fact, still drives, albeit with trans related noises, but probably not for long.
I HATE to have to see it go . I anticipated driving it until I circled the drain. Great car for another Mini enthusiast.
The asking price doesn't even cover the recent repairs but if no one wants it , I 'll part it out in the Spring.
If interested please text (I don't answer unknown numbers). 215-758-3562 Thank You.
The list of repairs and specs below.
Perfect Enthusiast Spec: (solid roof, manual AC, limited slip)
- Sport Combo
- Cold Weather Combo
- Limited Slip Differential
- Harmon Kardon
- Panther Black Leather
- Matching Interior Surface
- Multifunction Wheel
- Mods installed in 2006 right after purchase
- 19% Pulley,
- Borla Race Exhaust
- Helix intake
- Helix 19mm Rear Sway Bar
- Auto Up Window Module.
- Recent Repairs include:
- Supercharger Rebuild,
- Water pump
- Oil Pressure Sensor to address oil leak
- Serpentine belt, Idler and Tensioner
- Rear Sway Bar Links and Helix Bushings
- Helix Air Filter Replacement
- OE Window Regulator
- Steering Motor/Pump, Bosch OE replacement
- Timing Tensioner
- ABS sensor
- Front and rear pads
