R57 R57 No horn
Old Aug 27, 2022 | 06:19 PM
Ls40095's Avatar
Ls40095
R57 No horn
First Mini Cooper,
2015 convertible. Horn doesn’t work. Assumed it was the horns so bought new Hellas and still nothing..
Don’t know how to test for power. Is there a horn relay in passenger fuse box?
car has 100k on it.
Old Aug 29, 2022 | 11:03 AM
Ls40095's Avatar
Ls40095
Anyone please can anyone offer any help?
Old Aug 29, 2022 | 01:20 PM
michaelo's Avatar
michaelo
Have you tried changing the horn fuse? Just because it looks good, doesn't mean it is good.
Old Aug 29, 2022 | 01:32 PM
Ls40095's Avatar
Ls40095
I switched the fuse with another working circuit
Old Aug 29, 2022 | 01:42 PM
Ls40095's Avatar
Ls40095
I wonder if these are contacts that need sanded for proper contact to sound horn…I know this is a problem with newer minis 2016 and up
Old Nov 21, 2023 | 12:40 PM
RChandler's Avatar
RChandler
I have sanded the contacts, replaced the fuse, replaced the clock spring, tested the horns.
I JUST NEED TO FIND THE RELAY, it looks like on the r56 it is behind some of the passenger footwell fuse boxes but does not appear to be the case for r57, I see no fuses on the back side of that fuse panel.
Could anyone please point me in the direction of the relay?
Old Nov 21, 2023 | 12:47 PM
Ls40095's Avatar
Ls40095
I did the same then searched for relay and think it’s built into wiring harness. No removable relay that I’m aware of, that’s why I bought a wireless component to use a button provided to use horn…I was also told from other findings thst the dealers replace the steering wheel for repair
tylergoelz
Sep 25, 2019 03:18 PM
kimosabe
R57 :: Cabrio Talk (2009+)
Mar 26, 2019 04:50 PM
Mrelia
Jan 19, 2013 04:55 PM
Jahnnie
Jun 17, 2011 02:35 PM
lanevomr
May 12, 2010 06:53 PM
