Coolant leak through head bolt
Old Aug 17, 2022 | 11:29 AM
lvR552008's Avatar
lvR552008
Hello, new to the forum and hope someone can shed light on this subject. Working on my daughters 2008 R55, blew a radiator hose on the freeway but was able to pull to the emergency lane and engine died. Had it towed home and checked sure enough, coolant splashed everywhere in the engine compartment. Decided to pull head out, get it re-surfaced, install new gasket and seals, new head bolts etc. Here's the issue, before I pulled everything apart, there was no coolant inside the engine, after putting the top end back together, with correct torque, new HG etc., when I fill the system with coolant, I can see it coming out of the center front and rear head bolts. Do the bolt holes of these engines go through the water jackets and require thread sealant during install or is the head fubar?
Old Aug 18, 2022 | 05:52 PM
lvR552008's Avatar
lvR552008
I guess this has never happened to anyone, cheers.
Old Aug 19, 2022 | 01:19 PM
TVPostSound's Avatar
TVPostSound
Did you install a + 0.3 mm thicker head gasket? After machining head, a new head gasket with thicker
rubber coating needs to be used.
The water jackets are isolated with those rubber coatings.
Old Aug 19, 2022 | 01:39 PM
lvR552008's Avatar
lvR552008
Thanks for your reply. I asked the machine shop how much did they skimmed off the head and said 6 thousands of an inch not enough to warrant a thicker head gasket. Do you think I have to go with a thicker one? And if so, who would be a good source since my search always comes up with the standard .90mm thickness.
Old Aug 22, 2022 | 11:28 AM
Briscoec's Avatar
Briscoec
You have to have the surfaces immaculate before reinstalling with gasket. I'm talking immaculate. The un-resurfaced side has to look pristine. Use one of those green scotch guard pads. You will need three or four of them cut down in size. Clean surface till it looks polished.
Bonestock3
11
Sep 11, 2021 12:27 PM
DatOnePotato3030
May 6, 2018 09:08 PM
Hambrick
Jan 15, 2017 06:28 AM
nlinesk8s
Dec 6, 2016 10:59 AM
kurt112345
16
Oct 4, 2012 10:35 AM
