R52 interior light
Old Aug 3, 2022 | 08:13 PM
zabond's Avatar
zabond
interior light
2007 R52S JCW Mini Sport Limited edition model ,The middle interior light isn't working, if I push the overhead center switch the foot light on passengers side comes on[RHD] but main overhead light doesn't, I can't work out how to remove the lens/light assy to check the bulb, both the map lights work
any clues?
Russ from down under
Old Aug 6, 2022 | 02:59 PM
zabond's Avatar
zabond
finally got the light out after trying all the ways on google search with no luck, resorted to a bit of brut force and it came out, the previous owner must have had a similar problem and glued the light in with Araldite, because the locating lugs were broken off and the holding springs missing, so when I replace the globe I'll have to do the same but use silicon so it will be easier if I ever have to remove it again
Russ
lokiofcontrol
Jan 8, 2018 01:54 PM
BlackIce
May 3, 2016 01:39 AM
Dimi
Electrical
Jan 28, 2009 12:54 PM
Goldfinch
Aug 31, 2003 08:42 AM
