Rear WMW sway bar + adjustable end links for R50 R52 R53
For SaleSteering/Suspension
Price
$165• OBO
- Location Mountain View, CA, 94043, USA
- Condition Used
- Compatibility
| Make | Model | Year |
| Mini | R50: "Mk I" Mini One & Cooper | 2002 - 2008 |
| Mini | R52: "Mk I" Mini Convertible | 2002 - 2008 |
| Mini | R53: "Mk I" Mini Cooper S | 2002 - 2008 |
Available Items:
1) Rear Sway Bar, adjustable: $165 ($250 new)
2) Adjustable end links, Front pair: $95 ($155 new)
3) Adjustable end links, Rear pair: $95 ($155 new)
"WMW Rear Sway bar is the best bar you can get for your R52 R53 R55 R56 R57 R58 R59 MINI. This is the same as a solid 22mm swaybar. The difference is this bar is a hollow bar allowing us to save almost 8lbs over any solid bar. To do this the bar is 25.5mm, tubular, 4130 chrome moly sway bar weighing in at only 5.5 pounds! So the effective rate of the bar is equal to a solid 22mm bar.
The WMW Rear Sway bar has three adjustment positions with the softest setting being the more neutral balance. The middle setting will really aid the Mini's medium to long mid-corner speed where there will not be any throttle feathering needed to turn the car. The stiffest setting is most beneficial through very slow, tight corners where without the bar you would find yourself on and off throttle several times. With the WMW Rear sway bar, this type of corner should only be a one throttle application corner with a rear-steer feel. Although handling characteristics may vary depending on your set-up, each position of the WMW Rear sway bar is very distinct and useful. Now you have an advantage at the track and auto-cross course! The set comes complete with polyurethane bushings, bushing brackets and 90-degree zerk fittings for easy lubrication, and one sway bar.
Rate increase over stock. Rear: +226%, +294% & +383%
Bar comes finished in grey powder coat and includes greasable mounting brackets with poly sway bar bushings that have an H shape channel to hold the grease in and keep it quiet long term. "
