Hotchkis Sport Rear Camber Links for R50 R52 R53
For SaleSteering/Suspension
Price
$165• OBO
- Location Mountain View, CA, 94043, USA
- Condition Used
- Compatibility
| Make | Model | Year |
| Mini | R50: "Mk I" Mini One & Cooper | 2002 - 2008 |
| Mini | R52: "Mk I" Mini Convertible | 2002 - 2008 |
| Mini | R53: "Mk I" Mini Cooper S | 2002 - 2008 |
Hotchkis 13800 Sport Rear Camber Link Kit for Mini Cooper 2002 - 2008 R50 R52 R53
Hotchkis H-Sport Rear Camber Links are perfect for lowered Minis. They have an adjustment range from zero to negative four degrees for increased rear grip. The Sport Rear Camber Links are designed and tested to suit any street or track environment.
Each Link is simply adjusted by loosening the lock nuts and then rotating the hex center for more or less camber. The Hsport Camber Links themselves are made up of two tubular steel outer arms with a billet aluminum hex center. The polyurethane bushings can be greased by utilizing the zerk fittings at each end. Durable, yet highly functional, the Sport Camber Links give you the freedom to set your Mini's rear camber at any setting.
Now come all black for a cleaner look.
