R55 Blind Rivet Control Arm Bushing Carrier bolt
Old May 29, 2022 | 06:50 AM
LUKA1828's Avatar
LUKA1828
Blind Rivet Nut is broken and needs to be replaced for the Driver/Left Control Arm Bushing Carrier bolt. Is there a kit or a DYI method to fix it? A standard Rivet Nut will not work. Or will it if I bore out the OEM Blind Rivet Nut?
Regards, Luka1818
Old Jun 18, 2022 | 08:40 AM
LUKA1828's Avatar
LUKA1828
Fixed. Carrier bolt secured to 60 nm. After eyeballing the design of the damaged recessed nut, I opted to drill out the 10 mm fastner. Drilled out using an 11mm or 7/16 drill bit. Tapped in 12 MM 1.5 pitch using GEARWRENCH 12mm x 1.50 NF Plug Tap - 388731N from AMAZON. Acquired new 12 X 60 MM 1.5 pitch bolt and washer from an ACE Hardware Store. The Control ARM Bushing is secure.
Mini1776
May 9, 2022 07:35 AM
Mindspin311
Suspension
40
May 15, 2013 10:16 AM
Aeromax
Suspension
Feb 20, 2011 07:54 AM
usman88
Suspension
Nov 14, 2007 05:11 PM
