2006 Mini Cooper JCW Dark Silver 82K miles, w/LSD - Utah
2006 Mini R53: "Mk I" Mini Cooper S
  • 2006 Mini R53: "Mk I" Mini Cooper S - 2006 Mini Cooper JCW Dark Silver 82K miles, w/LSD - Utah - Used - VIN WMWRE33526TL22466 - 82,000 Miles - 4 cyl - 2WD - Manual - Hatchback - Gray - Salt Lake City, UT 84109, United States
    $11,950
    • OBO
  • Location Salt Lake City, UT, 84109, USA
  • VIN WMWRE33526TL22466
  • Mileage 82,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Gray
Mini is sold
I had this Mini on C&B but the sale fell through. It's one of a dozen or so that I've owned. I love it but with growing kids etc. I'm not sure it's the right car anymore. I go back and forth on it so no low ballers, please. Pictures are kind of all over the place. Brand new OEM headlight trim rings. I have also removed the black tape around the trim.
See below for full details. The previous owner replaced the clutch and serviced the supercharger, and water pump, among many of the other common wear parts. I replaced every oil-related gasket (oil cooler, oil filter to block, valve cover, oil pan, crank seal). Everything was done within the last 9k miles.
THIS... is a 2006 Mini Cooper S, finished in Dark Silver Metallic with a Panther Black interior.
- The attached Carfax history report lists no mileage discrepancies in this hatchback's past. It also shows that this Mini was registered in South Carolina and Georgia until 2021.
- Factory equipment includes the Cockpit Chrono Package, a sunroof, leatherette upholstery, front sport seats, and a Harman/Kardon sound system, according to a build sheet shown in the gallery.
- Modifications reported by the seller include 17-inch OZ Racing Superturismo GT wheels, BC Racing coilovers, and a strut tower brace. The full list of aftermarket parts installed on this Mini is below.
- This Cooper S is fitted with a factory-backed John Cooper Works tuning kit that includes a remapped ECU, an 11% reduction pulley for the supercharger, and a performance exhaust system, among other modifications. The kit's certificate of authenticity and serial number are pictured in the gallery.
Equipment
- Cockpit Chrono Package (additional gauges on the center stack)
- Sport-tuned suspension system
- Locking differential (IMPORTANT)
- Xenon headlights
- Fog lights
- Sunroof
- Leatherette upholstery
- Front sport seats
- Split-folding rear seats
- CD player
- Harman/Kardon sound system
Modifications
- John Cooper Works 200 tuning kit (remapped ECU, modified cylinder head, specific supercharger, 11% reduction supercharger pulley, performance exhaust system, John Cooper Works exterior badges and certificate of authenticity)
- 17-inch OZ Racing Superturismo GT wheels
- BC Racing coilovers
- Strut tower reinforcement plates
- Strut tower brace
- Rear camber links
- Aftermarket rear sway bar end links
- Paint protection film on some of the forward-facing surfaces
- Black grille
- Factory JCW side skirts
- Rear wiper removed
- "John Cooper Works"-branded shift ****
Known Flaws
- The attached Carfax vehicle report shows that "minor damage" was reported to the rear of this Mini Cooper in January 2022. Paintless dent removal (PDR) was performed to repair the damage.
- Minor chips on the front end
- Minor scratches on both bumpers and mirror caps
- Dent on the hood
- Creases on the front seats and a crack in the driver's seat outer bolster
Recent Service History (all within 9,000 miles)
- March 2022: Polished/restored headlights, radio button replaced, chrome headlight trim installed
- November 2021: Oil cooler gasket, valve cover gasket, oil filter-to-block gasket replaced, front crankshaft seal replaced, engine oil and filter changed, rust spots under the door weather stripping repaired
- October 2021: Seat-out interior detailed, oil pan gasket replaced
- Supercharger gaskets and oil
- Spark plugs
- Crankshaft position sensor o-ring
- Water pump
- Alternator
- Liquid-filled crankshaft pulley
- Harmonic balancer
- Clutch and flywheel (IMPORTANT)
- Guide tube and shifter bushings
- Transmission and differential fluids
- Power steering pump (used), lines, reservoir, and fittings
- Upper and lower ball joints
- Control arm bushings
- Sway bar bushings
- Passenger-side window regulator
Old May 25, 2022 | 07:17 PM
vulkandino's Avatar
vulkandino
This is a well-sorted R53 JCW. There are no leaks, no issues, no CEL, no funky sounds, pure supercharger and exhaust pops.
Price drop. Someone buy this clean car before I drop more money into a full Aero kit.
Old Jun 1, 2022 | 05:38 AM
vulkandino's Avatar
vulkandino
Just purchased a matching dark silver rear aero bumper. Also raised the suspension just over half an inch. Much more forgiving over bumps and easier to drive all-around.
Old Jun 10, 2022 | 09:04 PM
vulkandino's Avatar
vulkandino
New pictures and price drop.
