Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Clubman (R55), Cooper and Cooper S(R56), and Cabrio (R57).
I ordered five drain plug O-rings from PP, out of California. They sent me these five little brass things, that I have no clue what they are. I sent them a pic of a spare drain plug, with the 5 brass rings and they said the warehouse said they sent the correct part. I looked all over the place and found a used O-ring and took another picture and sent it. Customer service at P*****n P***s said the item number was correct and they sent the correct parts. I have never been so stunned in my life. Do they look at pictures? I will never, ever use PP again. I am deleting my account tomorrow. Cause I want to call an talk with someone that can look at the picture. ... Hello PP guy are you listening?
Sad day,
Briscoe
Sorry, I only just saw your picture (surfing with TOR browser and mostly not getting to see pictures on NAM) and realised that you meant the size of them. In Germany, "o-ring" refers to rubber o-ring gaskets so I thought they sent you rubber rings.
Gasket for oil pan plug is correct. For some reason I thought Pelican called them O-rings. I did click on the correct part online, it's a pretty simple process. They said they sent correct part number, too bad it was out of incorrect bin. It just gripes me to no end when I sent the picture. I even stated that there was no rush in replacing them, use the cheapest means to make it correct.
I can call my mini justa an S, but it doesn't make it one. Yep, they are both cars, but not the same. Off their website
Reason: add picture
Sad day,
Briscoe
Those little guys look way too small to be oil drain plug sealing rings... I've never ordered parts from Pelican. Sorry you had that experience.
I wasn't sure I'd get banned if I used the name Pelican Parts. I have good service, in the past if I had issues, just this time. I should have known the gaskets don't sell for 25 cents. I started using the Wix oil filter for this Mini and it comes with the oil holder rubber O ring and a new crush gasket. Plus it is a very fine particle strainer.
