Remote Oil Cooler Components
Accessories
  • Accessories - Remote Oil Cooler Components - New - 2008 to 2014 Mini R55: "Mk II" Mini Clubman - 2007 to 2013 Mini R56: "Mk II" Mini Hatch/Hardtop range - 2009 to 2014 Mini R57: "Mk II" Mini Convertible - Athens, GA 30601, United States
    $200
  • Location Athens, GA, 30601, USA
  • Condition New
  • Compatibility
Make Model Year
Mini R55: "Mk II" Mini Clubman 2008 - 2014
Mini R56: "Mk II" Mini Hatch/Hardtop range 2007 - 2013
Mini R57: "Mk II" Mini Convertible 2009 - 2014
I am selling some parts for converting to an external oil cooler on an R56. I am including a Mishimoto oil cooler, generic oil cooler bracket, and two different oil cooler adapter plates. I was compiling these to build my own remote oil cooler system, but then decided to go with the RPM kit instead. The black oil cooler plate is a generic adapter, while the silver one pictured is the Sneed 4 Speed plate. The Sneed plate was used for about a month and removed. You would need to source your own lines and fittings, as these are just some of the pieces of the puzzle. These were compiled for use on an N14 R56, but would work on an N18 as well. If you chose to use the Sneed plate you would need to source longer hardware. I'm just including both plates as I have no need for either anymore. The oil cooler bracket is attached to the cooler and already mocked up to be mounted on the top of the crash bar, though you can go a different route if needed. Hardware for that is included.
Price is $200 plus shipping, or free pickup at MOTD or around the Atlanta/Athens area.
Thanks for looking!
