Saikou Michi Dual Oil Catch Can & assorted PCV Fittings
For SaleEngine - Intake/Fuel
Price
$150
- Location Athens, GA, 30601, USA
- Condition Used
- Compatibility
| Make | Model | Year |
| Mini | R55: "Mk II" Mini Clubman | 2008 - 2010 |
| Mini | R56: "Mk II" Mini Hatch/Hardtop range | 2007 - 2010 |
I am selling a used Saikou Michi dual oil catch can, along with an assortment of pcv fittings for plumbing it. I used this until I changed valve covers and was able to make a proper -an fitting catch can setup. Included is the catch can, some mounting brackets, and an assortment of fittings you can use depending on your application. The hose I am including is setup to plug into the rear of the valve cover with or without the bsh boost tap piece. The black solo fitting adapts the pcv heating element to be able to run a hose to it. I am including a photo of one possible configuration with an oem style intake. As it is the catch can has two blanking plugs at the bottom, though this was done for the sake of space and I'd recommend changing those out for simple petcocks or fittings for remote drain valves. You can get 1/2npt petcocks for a few dollars.
This was used on an N14, I know nothing about the N18 valve covers and their fittings so I can't say if it would work there or not.
Price is $150 plus shipping, or free pickup at MOTD or around the Atlanta/Athens area.
Thanks for looking!
