09 JCW R56 fully loaded with lots of extra parts!!!
For Sale2009 Mini R56: "Mk II" Mini Hatch/Hardtop range
Price
$6,500
- Location Irvine, CA, 92603, USA
- Condition Used
- VIN WMWMF73559TW85511
- Mileage 151,200
- Drive Type 2WD
- Transmission Automatic
- Vehicle Type Coupe
- Exterior Color Gray
It is time to let go of my daily commuter. 2009 JCW R56 Mini Cooper. This car has been meticulously maintained to ensure drivability and reliability. I have done many repairs on common failure parts to make sure it did not break down on my drive to work. I recently changed jobs to a much closer spot and don’t need the extra car. There are also many upgraded parts along with some that I ran out of time to install. The pricing listed is very reasonable and includes all parts.
There are just a few imperfections that I am aware of that I will list. Overall body is in good shape with the exception of a couple of paint cracks near the passenger lights. Also there is currently a check engine light on for the catalytic converter failing. I have already purchased a cat less downpipe that I have a thermal wrapped to fix it. Light does not effect the performance. The lower front crank seal has just started to leak along with the turbo oil feed line. I have included a new seal and NM flex oil line to repair it.
This car will also have a branded title due to a low speed rear fender bender. While the car was getting repaired, I had the body shop respray all the arches, front bumper for rock chips and rear bumper.
There is plenty of life left in this mini and I just don’t have the time to maintain or upgrade it as I wish I can. Car has never been raced or driven hard. Let me know if there are any other questions.
Repairs:
Vacuum pump
Vacuum pressure solenoid and hoses
VANOs solenoid
Thermostat full housing
High Pressure fuel pump
Low Pressure fuel pump
Fuel filter and whole housing assembly
Valve cover and gasket
Timing chain and rail guide
Oil changed every 3500
Spark plug and coils
Newly painted front and rear bumper, side arches
Throttle body
Updated OEM wiper blade arms to newer style
Upgrades:
AEM intake
AEM red strut bar
Power flex engine mounts
KW Coilovers
Lower rear adjustable control arms
Custom Exhaust
Helix Union Jack led Taillight
6500k light bulbs
OEM Roof rails
Stubby antenna
Rear fog light switch assembly retrofit
P3 Gauge
AEM oil pressure gauge
Dual gauge mount from convertible
Updated NAV maps
New Antenna base unit
Rooster red interior
Jcw scuttles OEM
OEM blackline tail light surrounds
Forge Red Noise Generator Delete
Sneed4speed Boost muffler delete
New tires less than 2 wks old
JCW rare spoiler wing
JCW tuned
Carbon fiber hood scoop
Cravenspeed oil dip stick
BMW unlimited oil change 3yr plan
Extra Included Parts:
Carbon fiber belt line
OEM Mini LED driving lights with OEM switch/retrofit kit
New OEM JCW front grill with cutouts for driving lights
Oil pressure tap
Oil pressure setup
JCW 4 piston brakes complete with gp2 brake master cylinder assembly
Stop tech stainless steel brake lines
New NM turbo oil feed line
New crank hub seal
Downpipe thermal wrapped
M7 stage 2 tune (not installed or married)
Extra Valve Cover
