R56 Brake & Traction warning lights both YELLOW - no error codes
Old Apr 10, 2022 | 07:41 AM
Lars-of-D's Avatar
Lars-of-D
Hello, this is my first post.
My Brake & Traction warning lights both YELLOW. No OBD2 scan codes. Replaced both brake pad wear sensors. Replaced all four wheel-speed sensors. Brake fluid is at MAX. Checked the level sensors. Checked the steering angle sensor with my scanner, but no codes. Reset all codes, even none were present. Tried pressing and holding the traction control button, but nothing happens. I can still put it in SPORT mode, no problem. Looking for answers or suggestions, thanks.
PS: I bought this car in this condition, so I don't know the car's history.
Old Apr 28, 2022 | 08:12 AM
Lars-of-D's Avatar
Lars-of-D
Found the problem. Used a BMW/Mini specific scanner and found that the yaw-rate sensor (located under the passenger seat apparently) had become UNcalibrated. The scanner recalibrated it and all is good.
Old Apr 28, 2022 | 08:16 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Glad you figured it out. This shows the value of getting the appropriate scanner for these little monsters, too!
Old May 2, 2022 | 01:41 PM
schovil69's Avatar
schovil69
Which scanner did you use?
ururk
Jul 17, 2021 11:28 AM
pdeinc
Oct 17, 2018 05:48 AM
Swestes
Jul 5, 2018 10:17 PM
Markomatic
Jul 2, 2017 06:18 PM
Iamomeed
Mar 10, 2014 08:38 AM
