R56 ABS sensor replaced twice, suspect wire to controller? Or controller?
Old Mar 21, 2022 | 12:33 PM
Dropstone's Avatar
Dropstone
I get no signal to wheel speed sensor front left. And I’ve replaced it twice. I suspect now the wire that goes to the abs ECU or module? Does anyone know how to check that? Or what checks to make? 2008 Mini Cooper S.
Old Mar 21, 2022 | 02:13 PM
Dropstone's Avatar
Dropstone
I can’t find the abs module either. I figure that where the sensor wires go and I could check for continuity
Old Mar 22, 2022 | 01:56 AM
Vanski's Avatar
Vanski
According to the Bently Publishing, the ABS module is located in the engine compartment located just below the brake booster
Old Mar 22, 2022 | 08:35 AM
Dropstone's Avatar
Dropstone
Sweet thank you. Is there any way I can get that Bentley manual?
Old Mar 24, 2022 | 02:38 AM
Vanski's Avatar
Vanski
Bentley Publishing
You can get this on Amazon. The hardcover book is a bit pricey but it so well worth it because it is concise and so much better than Hanes and Chilton
Freakin Ninja
Jul 1, 2020 12:17 PM
blue agave
Nov 19, 2017 12:54 PM
siggie
Aug 17, 2017 08:38 AM
ghas
Jan 12, 2014 09:50 AM
MiniStupidfun
Sep 19, 2008 06:59 PM
