2007 Mini Cooper S...Well Maintained
2007 Mini R56: "Mk II" Mini Hatch/Hardtop range
  • 2007 Mini R56: "Mk II" Mini Hatch/Hardtop range - 2007 Mini Cooper S...Well Maintained - Used - VIN WMWMF73587TL86267 - 122,000 Miles - 4 cyl - 2WD - Manual - Hatchback - Black - Orlando, FL 32832, United States
    $7,500
    • OBO • Trade
  • Location Orlando, FL, 32832, USA
  • VIN WMWMF73587TL86267
  • Mileage 122,000
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Hatchback
  • Exterior Color Black
2007 Mini Cooper S finished in Astro Black Metallic with 122k miles for sale in great condition. This Mini is adult owned and has always been routinely washed and serviced. Many options including heated sport seats and panoramic sunroof. All major maintenance and minor upgrades have been performed within the last 5000 miles including the following:
-New OEM Mini timing chain, chain guides, tensioner and hardware
-New OEM Mini valve stem seals
-New OEM Mini water pump, serpentine belt, thermostat and coolant crossover pipe
-New OEM Mini oil cooler and oil filter housing gasket seals
-New OEM Mini Turbo Feed and Return lines
-New OEM Mini Vanos solenoid
-New OEM Mini vacuum pump and vacuum lines
-New OEM Mini crank seal, oil pan gasket, valve cover gasket
-All new filters including air, fuel, cabin and oil filters
-New brake pads, rotors and wear sensors
-New Bilstein struts and strut mounts
-New NGK iridium spark plugs
-New OEM Mini DMTL emissions pump
-All fluids replaced with synthetic including oil, transmission and brake fluids
-17” Enkei wheels with new 215/45/17 tires
-LED halo fog lights with daytime running lights
-New updated headlight and tail light housings with all LED bulbs
-New JBL speakers throughout
This Mini runs and drives great with no leaks or abnormal noises. All major repairs have been performed by local Mini specialist, Maitland Importers, with receipts available. Ac blows cold and there are no warning lights present on the dash. This car has been thoroughly maintained, and is ready to drive for years to come. 2 original Mini key fobs included. Clean title in hand.
