2016 R60 issues
Old Mar 6, 2022 | 07:00 PM
Raven Mocker's Avatar
Raven Mocker
2016 R60 issues
We’ve a 2016 R60 that we are having a few small issues with.
1) After changing the oil you are able to reset the maintenance warning. I’ve tried several methods to no end. Nothing seems to work.
2) The USB port does not work. I’m going to check the wiring as I’ve read it’s a common issue. If I don’t see or test a broken wire I’m replacing the USB port.
3) The gas gauge warning light is always on. You can have a fuel tank but that warning light remains on. The gauge it’s self works perfectly. This one is beginning to drive me crazy.
Old Mar 6, 2022 | 08:39 PM
navwizard's Avatar
navwizard
On the reset one, in my car with the ign on you hold the odometer reset for a long time, 10 seconds or more.
The display in the tach will change. You use the button on the stalk until you get to oil (oil can), then hold the button on the stalk a long time. Reset will come up, then you hold it again, you'll see a little clock symbol, and it will reset.
''Dan
Old Mar 7, 2022 | 12:01 PM
Raven Mocker
I will try that today. At the moment my wife has the Mini. Then I will let everyone know.
Old Mar 9, 2022 | 12:56 PM
Raven Mocker
''Dan
it worked! Thanks 😁
Old May 2, 2022 | 04:08 PM
scf's Avatar
scf
Need a pic of warning light please.
Do you always show miles to empty on your OBC?
jbluesky
Aug 31, 2019 06:41 AM
sprp85
F54 :: Clubman Talk (2015+)
Nov 20, 2017 09:00 AM
extranrg
Feb 16, 2017 12:29 PM
VariableR58
Apr 25, 2016 02:02 PM
