R56 2011 R56, After clock is set, will not save settings.
I have a 2011 R56, actually not mine, it is my wife's dream car, ice blue, she loves it. After replacing the battery, we noticed that after the clock is set, when I press select to save the settings and back up one menu level, the settings are not saved. I looked online, and there are discussions about issues with the IBS (Intelligent Battery System) but this car has just a normal negative battery terminal, not a box which is an indicator that the car has the IBS. I cannot find any additional info online to suggest what might be causing this issue. If anyone has any feedback, it would be greatly appreciated. We live quite a ways from a mini dealer, so it could be a long time before we would have a chance to have it checked out there.
I have a 2009 MCS and had a similar issue. My issue was that I was attempting to set timne using the buttons on large speedo/radio, However, when I switched to setting date/time using the button on end of turn-signal stalk and sub-menus displayed on bottom of tachometer, I was able to save the updated time I set.
Good luck,
W
Good luck,
W
