Drivetrain Cold Side Intercooler Pipes
Old Feb 2, 2022 | 03:13 PM
Darren Saccone Jr's Avatar
Darren Saccone Jr
Trying to install the M7 Speed Cold Side Intercooler Elbow Kit but I can't seem to remove this stock tubing. I've loosened the clamp and tried wiggling and pulling with all I have but it doesn't seem to budge. Does anybody have any ideas that could help? Thanks!
Old Feb 2, 2022 | 03:35 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Looks like its stuck on the throttle body? That hose will fuse itself to the throttle over time. When I replaced mine, I just cut it off. I figured it was getting replaced anyway...
Old Feb 2, 2022 | 03:36 PM
Darren Saccone Jr
what did you use to cut it off? I've tried with my pocket knife but its a thick tube
Old Feb 2, 2022 | 03:38 PM
Jason Cornelius's Avatar
Jason Cornelius
I used a coolant hose pick, nothing fancy, just the simple 90 degree one. Force it between hose and throttle body and run it around the hose the best you can, got to break its seal.
Old Feb 2, 2022 | 03:39 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yeah, a pocket knife won't touch it. You'll need a razor knife.
I used a utility knife:
https://www.lowes.com/pd/Kobalt-Comp...ife/5001789221
Jason Cornelius
Sharp razor blade and some time, will get you through it as well.
Mini242
Nov 4, 2021 10:27 AM
jamjr721
Aug 26, 2020 07:54 PM
dtilden
Jun 24, 2020 03:44 PM
N54
May 19, 2020 04:19 PM
minimusprime
Jan 23, 2007 12:42 PM
